Chris NottAH Fabrications
Results 1 to 7 of 7
    Jan 2013
    Somerset
    Axel nut keeps coming loose!
    Hi, I recently had my wheel bearing changed (front drivers side) and had this issue before the change and I'm still getting it now, the axel nut just keeps coming loose! Any ideas on why this is? I keep torquing it up with a long bar, but after a few days it comes loose again! Any help greatly appreciated!
    Jamie
    Lewis583's Avatar
    Mar 2010
    833
    Are you torquing it up to spec or just give it some welly with a bar? New bolt/nut used?
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Jan 2013
    Somerset
    Just giving it some welly with a long bar! Yes new nut used, came with the bearing kit!
    Lewis583's Avatar
    Mar 2010
    833
    Could stand a chance that the drive flange hasn't been pressed far enough into the bearing, hence why it keeps coming undone.
    In the bearing kit, was it just a bearing or was it a complete kit (bearing/hub flange/bearing housing)?
    If it was just a bearing on it's own, then it could stand a chance that the hub flange wasn't pressed fully into the bearing, hence when you tighten the nut/bolt the hub flange works it's way further into the bearing and it appearing to come loose.
    My advice is; If you had a garage do the job, take it back; If you did it yourself and you are 100% sure the bearing was fitted correctly/pressed in fully, TORQUE the hub nut up to the correct setting and keep an eye on it.
    Full VCDS
    Oct 2007
    111
    wrong size bolt? I would have thought if it wasn't pressed on far enough doing it up should move it on a bit unless this is what's happening and the bolt appears loose until its 'home' what about a bit of locktite.
    Lewis583's Avatar
    Mar 2010
    833
    It can take tonnes(literal tonnes, not as in "loads") of pressure to push in a hub flange/wheel bearing.
    Full VCDS
    Oct 2007
    111
    a wheel bearing yes and it would have to be all the way in to put the cir clip in place.. but a flange normally presses straight in with out too much force.
  1. Exhaust manifold bolts coming loose on 2001 S3
    By viper6 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2009, 08:44
  2. Back speakers keep coming on and off
    By boson in forum In-Car Entertainment
    Last Post: 3rd June 2009, 17:42
  3. boot/door warning light keeps coming on for no reason
    By deanosavanna in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th July 2007, 19:44
  4. Replies: 8
    Last Post: 19th January 2006, 23:06
  5. Anyone know if brake sensor is easy to come loose...?
    By Leon in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2005, 20:45
