Chris NottJMB Retrofits
    kachnak's Avatar
    Sala, Slovakia
    117
    Question how to remove climatization (no clima control panel)
    Hello,
    Anybody know if here on this forum (or vwvortex) is some how to guide to remove climatization? I found nothing.
    I have problem with it, and also some error is in memory. I think clima motor is bad or something like that because i heard wery strong mechanical vibrations if clima was turned ON.
    Thank you.
    Audi S3 1.8T 154kw 210hp APY 1999
    GET LOW, NO MATTER HOW!
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    It could be the foam inside the fan unit behind the dashboard making the vibrations. You can remove the glovebox and access it although it's a very tight squeeze.
    '02 A3 TDI quattro sport
    8L IS DE BEST
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    187
    scan it and tell us what faults do you have.
    Currently not in the country
  1. how to remove climate control unit?
    By _G_ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th June 2012, 21:04
  2. How to remove climate control unit switches/facia?
    By c_w in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th September 2010, 12:59
  3. How to remove climate control panel..
    By Loneranger in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th September 2009, 21:05
  4. how do remove the climate control unit
    By rasA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th May 2006, 22:53
  5. Removing Climate Control Panel
    By little_wing in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th September 2005, 19:25
