Volks AutosAH Fabrications
Results 1 to 8 of 8
    chuffer's Avatar
    Jul 2003
    Berkshire
    70
    No brake lights!
    I've got no brake lights, what could it be? (98 A3 1.8T)
    I've changed the bulbs.
    28v6
    Re: No brake lights!
    Bad Earth? Fault in the Brake switch at the foot pedal.... [img]/ubbthreads/images/graemlins/froggie_red.gif[/img]
    PaulS3's Avatar
    UK
    988
    fuse blown or any mentioned above could cause it.
    239
    yep i agree, i would think its likely to be the brake switch at the foot pedal, easy to replace yourself
    Aug 2003
    Surrey
    469
    If brake light switch then this should help explain where/what it is:
    http://forums.vwvortex.com/zerothread?id=1158315
    chuffer's Avatar
    Jul 2003
    Berkshire
    70
    Yeap, the brake pedal switch
    imported_stuartkern
    Guys, could this be the same problem with mine, except it's the reverse lights that won't work?
    Oct 2005
    wales
    50
    reverse switch may be at fault, try shorting wire's out at switch to see if lamps come on.
    used a fused wire if you can to avoid grounding it, inline 5amp would be more than enough
