EM TuningVolks Autos
    Dec 2012
    Suffolk
    39
    Explain how timings used to change performance?
    Hi
    Just curious and trying to understand whats done with the timing to adjust the performance/power when having a remap. Whats done with it and what does it actually change.
    Dan
    beachbuggy's Avatar
    Surrey
    1,745
    Quote Originally Posted by salisbury1985 View Post
    Hi
    Dan
    Timing on the me7 found in most Audi's is a little different to a standalone ECU. It works fundamentally off 2 series of timing maps. Timing revolves around a torque based map. If the engine wasn't limited by knock then it would run basically the figure put in the map, but it always is. So what happens is the ECU advances timing towards this figure and when knock or the onset is detected will reduce timing to combat knock. The other timing map is the one used to give an ignition value during this phase. Again due to the nature of the ECU and its protection systems adjusting timing in the maps can have huge effect for small changes. For instance. Say the ECU determines that the knock threshold at 18 degrees advance has been passed, it will then pull timing typically by 3 degrees until it senses the knock is gone and resume at 15 (18-3) By reducing the timing figure by 1degree you might find the threshold isn't met and 17degrees is held. So now by running 1 less degree you can in effect gain 2! And so on. It is more complicated than that as other routines , lambda, torque monitoring, Vvt , egt etc all play their part as well in the over all final timing value. Its a very safe method , and certainly not ideal for all out tunning!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Ignition timing - Wikipedia, the free encyclopedia
    Timing advance essentially starts the combustion process as early as possible on the compression stroke to make best use of the energy released by the explosion of fuel/air mix...
    <tuffty/>
    Feb 2014
    136
    Good topic, more ignition advance more power
  1. RNS-E with Audi Bluetooth & how to use vioce dialling.
    By imported_G4JSG in forum In-Car Entertainment
    Last Post: 8th January 2006, 20:32
  2. How to use a Forum
    By docurley in forum General Chat
    Last Post: 1st February 2005, 23:35
  3. How many posts to change status ?
    By hop2407 in forum General Chat
    Last Post: 9th January 2005, 11:27
  4. 0-60 times and gear changes
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th April 2004, 08:47
  5. S4 : how to drive for max performance?!
    By gorlor in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th August 2003, 18:06
