Like Tree1Likes
  • 1 Post By Vex182
Thread: coil pack question?
    James TQ's Avatar
    Apr 2012
    Essex
    548
    coil pack question?
    so after the last couple of days my car playing up on idle and when accelerating its starting to missfire which points toward coils/harness/plugs, plugs are bosch super 4's few months old wire and plugs look original, i have bolt down coils and a friend with a 1.8t ibiza has push downs, can i use his coils in my block to test them, he also has 1 new one spare so can i run 1 push down 3 bolt down to see if my coils are at fault? can faulty coils cause bad idle? thanks
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    I believe you can use push downs if you have bolt downs, it's not ideal but you can mix and match, and a faulty coil will cause bad idle.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    899
    Add Vex182 on Facebook
    I melted a Bosch super 4 plug in my car after his a couple of months, a few others have has issues with the plugs before so double check they are ok. I only use NGK from now on.
    Birdy likes this.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    James TQ's Avatar
    Apr 2012
    Essex
    548
    if its the plugs or a plug at fault would it be constant miss fire as it seems mines random?
    James TQ's Avatar
    Apr 2012
    Essex
    548
    Got home scanned it... Nothing's to say of any miss fire?! It struggles then you can hear it pop?! Anyone please
    Vex182's Avatar
    Apr 2012
    Hinckley
    899
    Mine seemed to drive ok until I gave it some stick. Would be worth checking them.
  1. Daft question about Coil Packs
    By S3_chris 11 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2012, 10:53
  2. coil pack questions?
    By sk8xtrm in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st January 2011, 23:42
  3. quick coil pack question
    By domburg in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2010, 14:13
  4. Coil pack question
    By Haglos in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2010, 20:04
  5. Hi All - Coil Pack Question
    By heli_madken in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th April 2008, 12:44
