Volks AutosBadger5
Results 1 to 8 of 8
Thread: head gasket
    Jan 2012
    powys
    59
    head gasket
    hi i think my head gasket has gone on my pd 150 , if i drive it hard the water becomes all bubbly in the water tank , nothing in the oil and my coolant is still red , and coolant tank smells abit off.
    if it is my head gasket how much would this cost me.
    any where is shropshire
    cheers ray
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,389
    You need a test doing first to make sure it is your head gasket gone. £30 at most decent garages.
    head gasket last time I had one done was £870 inc vat. On a civic.
    Sean
    Current: 2013 Audi A3 2.0 tdi s line 8V in black SD nav+ extras, E46 BMW M3, 1971 Volvo p1800, 2014 Ford transit sport 155ps ;-)
    Previous : Focus st 225 stage 1 (265 bhp and too much torque), 2002 audi s3 bam engine completely OEM, 2001 Audi a3 1.8 TQS 221bhp and about 20 other cars, majority civics ek4/ek9 and Bmw / Audi soot chucker's!
    phil miller's Avatar
    Sep 2012
    Devon
    843
    It will be your water pump dude, head gaskets arent an issue on the 150 PDs
    ​Wish Rachel would let me have my TDI mk5 back
    Mar 2010
    Durham NE
    578
    Re: head gasket
    Um... Not a issue? Ive done a few lol, are your coolant pipes hot top and bottom? Are they rock hard to squeeze after a hard run? Heaters hot when on boost? Yes the water pump impella comes loose, then no flow around system, but it will boil itself!
    James
    Silver Audi 8L S3
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    and many many cars and bikes in the past!!
    Sep 2012
    Devon
    843
    Quote Originally Posted by AudiS3-Turbo View Post
    getting a 150 to boil is a lot harder than your making it sound, with the temps we have had this week getting one up to temp is hard enough, head gasket issue on 150s REALLY, a gasket failure would show more than whats showing, my money is on water pump, and just to put it in to context, i know of a 150 passat (same apart from floor pan) and that had water pump issues in the summer, it never boiled and the bloke drove it like on a track, there not an issue first off remove the stat and finger the pump, it really is that easy
    Mar 2010
    Durham NE
    578
    Re: head gasket
    Then how do you figure the micro bubbles in the header tank? Why bother with the water pump if they are that hard to boil... Or is it just there for the heaters?
    Just to add it does not need to boil to get bubbles in the system, boost can do this, I would get it checked out if in doubt.
    James
    Silver Audi 8L S3
    Jan 2012
    powys
    59
    thanks guys bottom pipe from rad to engine block is cold and the pipe that enters top of rad is very hot .
    the water pipe leaving the block on the back of the engine is also hot.
    i disconnected the small return pipe back to the reseiviour and sent it through the top and its not a steady flow it spits then flow then spits and flows ......................
    Ray
    Sep 2012
    Devon
    843
    Like I said water pump
  1. head gasket going!!!
    By killa_z in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th December 2006, 14:58
  2. Anyone done Audi S3 head gasket?
    By myrichdad in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2006, 22:35
  3. Head Gasket gone - thin caramel film on oil cap
    By VPMD7A in forum TT/TT-S/TT-RS Forum
    Last Post: 1st August 2006, 22:45
  4. 1995 S6, blown head gasket?
    By imported_BkkS6 in forum General Technical / How To
    Last Post: 6th October 2004, 17:46
  5. Head gasket wear in time?
    By FrOgR in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th June 2004, 15:06
