Hi everyone, does anyone think they could do me the favour of looking over my fault codes and give me any guidance as to what I'd need to replace?
The main problem is that my air con is not working, I've refilled the system with fresh refrigerant etc but the problem still persists. From looking at the fault codes I'm suspecting something is up with either the compressor or a leak somewhere?
The second is the fault codes that's to do with the alarm system, as for this I have no idea what these codes mean or if its so serious my alarm wouldn't be triggered at all?
& the last is that my airbag warning light is on, I've read up that this could be to do with the airbag wiring underneath the passenger seat coming loose or breaking?
Thanks in advance
-Dan
Address 01: Engine Labels: 06A-906-019-AEH.lbl
Part No: 06A 906 019 AM
Component: 1.6l 2V/R4 SIMOS HS2585
Coding: 04000
Shop #: WSC 06313
VCID: 6ED9EB722A0CEC68C39
2 Faults Found:
01013 - A/C Compressor Load Signal
31-00 - Open or Short to Ground
Readiness: N/A
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 D
Component: A3 KLIMAVOLLAUTOMAT_D75
Coding: 03141
Shop #: WSC 06313
VCID: 2953D86ED362CB5056B
2 Faults Found:
00792 - A/C Pressure Switch (F129)
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 8L0-959-655-AI7.lbl
Part No: 8L0 959 655 F
Component: Airbag 7 Audi 0505
Coding: 00104
Shop #: WSC 06313
VCID: 418360CE4B1223106EB
2 Faults Found:
00589 - Airbag Igniter 1; Passenger Side (N131)
32-10 - Resistance too High - Intermittent
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 P
Component: CV-Pump, Alarm, RC D13
Coding: 13130
Shop #: WSC 06313
VCID: 42816FC24E143808771
12 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
01134 - Alarm Horn (H12)
76-00 - Terminal 30 missing
77-00 - Internal Supply Voltage
49-00 - No Communications
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 06313
VCID: E0C5054A60D8CA18C15
1 Fault Found:
01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
35-00 - -
Thanks in advance
-Dan
Coding: 04000
Shop #: WSC 06313
2 Faults Found:
Readiness: N/A
Coding: 03141
Shop #: WSC 06313
2 Faults Found:
Coding: 00104
Shop #: WSC 06313
2 Faults Found:
Coding: 13130
Shop #: WSC 06313
12 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
Coding: 00001
Shop #: WSC 06313
1 Fault Found:
35-00 - -
