Chris NottJMB Retrofits
    Dec 2011
    Bedfordshire
    142
    Anyone in Bedfordshire or surrounding areas that would be kind enough to scan my car?
    Hi as above really I have a code reader which is giving me no codes now I had a camshaft position sensor fault which I have now sorted. The thing is the car has started juddering when accelerating the clutch does need replacing as its been slipping but only in high gears so still been driving it with no problem but now I get a loud tapping sound when I accelerate from 3000 an on does not do it when not in gear it revs fine and when it's warmed up it judderes and hesitates could this be the clutch? I don't seen to hav a vac leak as I have read about I have not long changed the plugs could it maybe be a coil pack.
    But if anyone would be kind enough to scan or take a look at it i would pay it would be apprecaited
    Any help would be welcome thanks
    Forgot to add the car is a apy s3
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,453
    VCDS (formerly VAG-COM) forum
    Have a look on the vcds map
    Dec 2011
    Bedfordshire
    142
    Quote Originally Posted by Sandra View Post
    Thanks Sandra just looked on there and messaged a few members hopefully they will get back to me.
  1. anyone out their in the plymouth area that could plug me in and help me with vag com
    By cominatcha in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd March 2012, 10:24
  2. ANYONE IN LIVERPOOL OR SURROUND AREAS WITH VAGCOM **ANYONE HELP**
    By AUDI A4 SLINE QUATTRO 2.0 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th June 2010, 16:51
  3. Anyone have vagcom in London area that can show me how it works?
    By drewbee in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th January 2010, 06:20
  4. Anyone in the Emsworth/Hampshire area...
    By mitalm in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th September 2007, 22:11
  5. Anyone wanna meet in Lancs area (Chorley area)
    By DaveS3Turbo in forum Major UK Events
    Last Post: 29th October 2003, 18:58
