Results 1 to 13 of 13
    Mar 2013
    7
    Front mount intercooler n75 pipe
    Hi there. Fitted my new front mount yesterday but having a bit of a problem with the pipe work for the n75. On the kit I have there is only one pipe to replace the two old ones. It's the biggest of the two that's there. What should I do with the smaller of the two pipes? Does it get blanked of? Bit confused with it really.
    Any help would be much appreciated.
    Cheers, Dave.
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,234
    does the pipe look like this your talking about ?
    if so the little pipe goes to the N75 valve
    the bigger pipe goes to the dump valve
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Mar 2013
    7
    Aye, my pipe is the same as the top picture but mine does not have the smaller pipe coming out of it. Do you know where I could get one of them?
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,234
    your have to get one welded in, or tap a thread and liquid weld one in.
    Mar 2013
    7
    Ah bugger. By liquid weld do you mean chemical metal or something similar? Don't suppose you know where I could get one of the small pipes to fit to mine? Also is it still ok to drive as it is?
    phil miller's Avatar
    Sep 2012
    Devon
    843
    Welding is ok but you will need to smoke test it to make sure it doesnt weep boost, best way is chemical metal, a tube is around the £8 mark, i welded both of mine (n75 and DV) and both have weeps, ive got some chem metal so will put that on asap
    as for a N75 take off pipe, i cut the take off, off my old pipe and drilled a hole in the new FM charge pipe then welded the take off on, bust way as its the correct size dude
    ​Wish Rachel would let me have my TDI mk5 back
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    402
    I used a metal tyre valve bolted on the boost pipe then chemical metalled round it been fine for about 18 months
    Mar 2013
    7
    Thanks for the replies no where open to get any now so will have to wait till tomorrow. Do you know if its still ok to drive without that pipe on?
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    402
    The actuator will get no vac supply so not really mate
    Mar 2013
    7
    Ok thanks il just leave it till the morn then. Hopefully get it sorted tomorrow.
    Is it not possible to buy a pipe with it already fitted? Seems pretty stupid selling an intercooler kit that u then have to go an weld bits to for it to fit lol
    Mar 2013
    7
    Managed to get a pipe chemical metalled on today and put everything back together and then fired it up and took it for a drive. Engine runs fine but won't boost. Only Gets 2 maybe 3 psi. Also a very deep loud throaty noise accelerating.
    anybody know what this could be? Pretty puzzled to be honest :s
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,234
    big boost leak ?
    didn't put the N75 back correctly ?
    Mar 2013
    7
    Aye one of the pipes had popped off. Never noticed it.
  1. big front mount intercooler and piping wanted
    By harveyS3 in forum For Sale/Wanted - Audi Parts
    Last Post: 10th August 2011, 22:00
  2. Piping up a Front Mounted Intercooler (URS6)
    By smogthemog in forum Tuning
    Last Post: 27th December 2006, 17:40
  3. Front Mount Intercooler
    By ashacre in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2005, 10:48
  4. Front-mount intercooler???
    By sport99quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th November 2004, 06:03
  5. S3 front mount intercooler
    By martin3310 in forum Tuning
    Last Post: 14th May 2004, 09:12
