Monster MotorsportEM Tuning
    Jan 2013
    17
    Should i be concerned ?
    Hi,
    VAG COM has pulled this code up , is this of any concern ? Do notice the dash flash occasionally ?
    Address 01: Engine Labels: 06A-906-033-APF.LBL
    Controller: 06A 906 033 BD
    Component: SIMOS33 1.6l 2V 00HS4582
    Coding: 00011
    Shop #: WSC 06435
    VCID: 62B7298BFD57
    WAUZZZ8L63A040143 AUZ5Z0B6245080
    1 Fault Found:
    17925 - Power Supply Relay for ECU (J271 or J363): Electrical Malfunction
    P1517 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: None
    Controller: 1C0 907 379 M
    Component: ESP FRONT MK60 0102
    Coding: 0011266
    Shop #: WSC 06435
    VCID: 341B9FD31723
    No fault code found.
    Thanks!
    phil miller's Avatar
    Sep 2012
    Devon
    843
    If it was me id order a new relay, replace it and keep an eye on the codes, it only takes the relay to not click once to throw a code
    ​Wish Rachel would let me have my TDI mk5 back
  1. fuse missing, should i be concerned.
    By kalem4 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th September 2011, 12:35
  2. Central Locking Click; Should I be Concerned?
    By jdp1962 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th September 2007, 20:30
  3. What should I do???
    By Steve_C_NWales in forum General Chat
    Last Post: 11th April 2003, 22:24
  4. WHICH WAS ROUND SHOULD A DV GO?
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2003, 14:41
