Should i be concerned ?
geese
NULL
Hi,
VAG COM has pulled this code up , is this of any concern ? Do notice the dash flash occasionally ?
Address 01: Engine Labels: 06A-906-033-APF.LBL
Controller: 06A 906 033 BD
Component: SIMOS33 1.6l 2V 00HS4582
Coding: 00011
Shop #: WSC 06435
VCID: 62B7298BFD57
WAUZZZ8L63A040143 AUZ5Z0B6245080
1 Fault Found:
17925 - Power Supply Relay for ECU (J271 or J363): Electrical Malfunction
P1517 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: None
Controller: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0011266
Shop #: WSC 06435
VCID: 341B9FD31723
No fault code found.
Thanks!
If it was me id order a new relay, replace it and keep an eye on the codes, it only takes the relay to not click once to throw a code
