Sky InsuranceVolks Autos
Results 1 to 7 of 7
    James TQ's Avatar
    Apr 2012
    Essex
    548
    Replacing abs pump
    Is it linked to the Ecu as I bought a spare pump a while back and it said Ecu aswell? Question is can I straight swap them as I'm getting code 01276, I paid pennies for the pump and can't find one for my engine code? Any ideas?
    Essflee's Avatar
    Mar 2008
    2,007
    I'm pretty sure there are several different abs pumps, all look the same but varying codes and you have to use a pump with the same code as the one on your car/ecu, big head ache trying to find one second hand.
    revo'd
    James TQ's Avatar
    Apr 2012
    Essex
    548
    Tell me about it! Is there anyone who can recon them?
    James TQ's Avatar
    Apr 2012
    Essex
    548
    Also is the Ecu attached, if I got a remap and the replaced the unit would I be wasting money?
    James TQ's Avatar
    Apr 2012
    Essex
    548
    Part number is 1j0 614 217 f if anyone has one they wish to part with
    phil miller's Avatar
    Sep 2012
    Devon
    843
    BBA reman can fix them, you will need one with the same part number and you will need to have the soft coding change to its the same as your old one
    The ABS control module is part of the pump dude
    ​Wish Rachel would let me have my TDI mk5 back
    James TQ's Avatar
    Apr 2012
    Essex
    548
    Looking about on eBay there's a few forsale around 100 so it's not too bad
  1. abs pump wanted
    By ian52 in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th March 2009, 19:58
  2. Replacing oil pump!
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th August 2008, 19:31
  3. Replacing fuel pump on 1.8T
    By Beef in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd July 2008, 09:54
  4. ABS Pump Control Unit
    By jitvv in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2007, 10:46
  5. 8L A3 ABS Pump Fault & Repair!
    By Tallpaul in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th June 2006, 15:37
