AH FabricationsSky Insurance
Thread: VCDS Logs
    Sep 2005
    Derbyshire
    180
    VCDS Logs
    Afternoon Ladies and Gents,
    Just done a few logs with my new VCDS cable (fear I may lose a few tanks of petrol because of this) and have a few q's.
    Firstly i've logged block 002 just to get an idea of gs/sec and it seems a little below my expectations.
    The car is a a APY (1999) S3 with a generic Custom Code stage 1 map with a B5 v3.0 TIP and Jetex Filter, N249, N112? and SAi removed (resistors in place) I have a Catch Can to fit but it's been a little cold recently.
    Now according to Block 002 I get a peak of 186.53 at 6360rpm, however the gs/sec is around 170+ between 5080rpm and redline.
    Does this seem normal to you? I don't believe the car has ever had a new MAF, could this explain why it seems low to me or are my expectations too high for a 14 year old car
    Cheers gents.
    Sep 2010
    Devon
    756
    Looks a little low, should really be looking around the 210 mark with your map and TIP etc I would think. If its never had a new maf then you want to be getting a nice shiny new Bosch one from TPS or Audi, not GSF/ECP. Any fault codes showing?
    Badger 5 tuned 340 bhp / 350 lbft sleeper
    Sep 2005
    Derbyshire
    180
    No fault codes, apart from no comm with alarm horn, which I alredy knew about.
    I get a nice discount at ECP, what's wrong with their MAFs? Or is it due to them not being OE compared to TPS etc.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,609
    186gs is a little low tbh... a MAF from ECP is fine as long as its a Bosch one and not a no name pattern part...
    <tuffty/>
    Sep 2005
    Derbyshire
    180
    <tuffty/>
    Thanks Tuffty, I was kind of hoping one from ECP would be okay, it was only ever going to be a Bosch one anyway.
    What else should I be logging and looking for on VCDS to check the integrity of the car?
    I've done a cheeky Block 120 log as well (who needs a RR? haha) and done the BHP / Torque vs RPM graph and it appears to be around 220-230 BHP.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,609
    Bit limited on your narrowband ecu but 020 (timing pull), 115 (boost) and checking block 032 (fuel trims) are a good idea
    <tuffty/>
  1. Revo on AGU MAF VCDS log
    By StupidFlanders in forum VCDS (formerly VAG-COM) forum
    Last Post: 28th September 2011, 09:58
  2. VCDS Log 3rd Gear
    By Zeus12 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2011, 21:50
  3. VCDS logging suggestions on what to log.
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2011, 16:02
  4. VCDS log - Take a look?
    By Stanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th March 2011, 21:24
  5. MAF and Boost VCDS Logs, what to you think of mine?
    By ben_turbo1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th August 2010, 15:17
