Chris NottAH Fabrications
Results 1 to 8 of 8
    Feb 2013
    23
    double din to single din conversion question
    i have a 2001 s3 and want to convert from my double din setup to single din.
    so far ive got most things i think. i have bought the inner single cage with climate control / underneath compartment / wiring harness for the sterio conversion. (i have a bose double din sterio set-up at the moment)
    what i want to know is , is the ariel going to be a straight fit into my aftermarket sterio or will i need an adapter for that also?
    if so could someone point me in the right direction of what i need to buy.
    many thanks
    steve
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    Just a thought but find someone that want to go from single DIN to double DIN and arrange to swap parts one weekend.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Feb 2013
    23
    i have all the parts though. just wanted to know about the ariel plug. if its a standard one on it just now or needs some kind of adapter.
    PiranhaMan's Avatar
    Jul 2012
    Manchester
    90
    think its one of these you need mate
    ... CT27AA05 Aerial/Antenna VAG Active ISO Adaptor
    2002 Audi S3
    Ming Blue
    "Gasses go into the turbocharger and spins it... witchcraft happens and you go faster" - Jeremy Clarkson
    Feb 2013
    23
    Quote Originally Posted by PiranhaMan View Post
    thanks mate
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    What are you going to do with you double din bits as I've got single and want to go double.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    Cobra88's Avatar
    Sep 2011
    Live in Ipswich Suffolk (orig from W London)
    435
    Drive over to me and i will swap my single din for your double including fitting
    if you have heated seats as i need the switches on the Hvac unit (mine has heated seats)
    sorry guys but worth a try
    2004 Audi A4 (B6) 1.9Tdi 130 Sport (6) Avant in Dolphin Grey.
    18" S4 AVUS, RS4 Rear Roll Bar, Leather Alacantra Sport Seats, Shark Performance 170 Remap,
    BOSE, XtronsA4A double din, Full DIS, Autolocks & Alarm Chirp.
    Avant Sport 1.8T Valance with twin exit.
    Feb 2013
    23
    ill be selling the bits once removed. still not got round to doing it yet but will be done in the next few weeks. the sterio / cage / aircon unit and surround will be going altogether hopefully. have to see what interest is kicking about when its time. i dont need any single din bits as i have the lot now.
  1. S3 double din to single din conversion
    By <tuffty/> in forum In-Car Entertainment
    Last Post: 7th November 2011, 14:07
  2. 2003 S3 Double Din to Single Din Fascia
    By SWAMP DONKEY in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th June 2010, 13:28
  3. Double din to single DIN
    By Effect in forum In-Car Entertainment
    Last Post: 28th April 2007, 00:05
  4. double din to single din.
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th April 2007, 13:53
  5. Double DIN to single DIN adapter
    By AndyMac in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th November 2006, 08:58
