Volks AutosMonster Motorsport
Results 1 to 7 of 7
Thread: Canbus
    Mar 2013
    Bridgwater, Somerset
    45
    Canbus
    I have a canbus system on my bike, so I know that previous faults when repaired, you have to reset the canbus system memory values to zero or the canbus just keeps saying that the fault is still there.
    So I am assuming that as the canbus said that the car's hatch was still open when in fact it was locked shut that I will have to get someone to reset the canbus on our car.
    What do you think ?
    Lewis583's Avatar
    Mar 2010
    833
    Canbus is just the communication protocol that allows the control units on a car to talk to each other. I think you mean fault codes.
    If there is a fault code stored for boot hatch lock switch position open circuit/plausibility and you have had the switch repaired/replaced, then yes the fault code will require clearing with the use of a diagnostic system. VCDS for example.
    The lock switch doesn't always log a fault code though. So if the car still reports that the boot hatch is open when it is shut, and the switch has been replaced with a new/known working lock switch and there are no fault codes stored. Then I would be checking the wiring to the switch. Particularly around where the loom goes from car body to the hatch.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    The boot switches (and the door switches for that matter) are a common fault... most of the time they don't register that the door/boot is open..
    8L cars use K-Line communications by the way
    <tuffty/>
    Mar 2013
    45
    Hi guys.
    I went outside with the workshop book and followed the steps on how to refit the rear hatch lock
    And now I can say the light for the tailgate goes out when the car ignition is turned on.
    Feb 2012
    Denmark, Copenhagen
    199
    So, i have me an A3 8L from 2002. 1.8T. No idea if its an Ambiente or Ambition model. Have anyone found out a sure way to tell if it has canbus or not? I an trying to install aftermarket HIDs. Mostly info i find by using google is in german.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    8L comms are K-Line and only use canbus for the instruments/radio..
    <tuffty/>
    Feb 2012
    Denmark, Copenhagen
    199
    Thank you tuffy
  1. Which Audi HU's Work In A3 8L (CANBUS)?
    By Tooks in forum In-Car Entertainment
    Last Post: 10th April 2008, 12:58
  2. Canbus
    By Boydie in forum In-Car Entertainment
    Last Post: 30th January 2007, 14:58
  3. obd or obd2 or canbus?? 51 plate s3
    By jedwa115 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th September 2006, 15:59
  4. Canbus problems
    By clcollins in forum In-Car Entertainment
    Last Post: 6th June 2004, 18:56
