Volks AutosAH Fabrications
Thread: N75 question
    Scullies's Avatar
    Feb 2012
    Dubai
    1,253
    N75 question
    Is it harmfully to the engine to run with the N75 electrically disconnected?
    My thoughts are to fit a switch into the power feed on the N75 harness to cut the power and act as a valet mode. Would this work?
    Heard too many stories about valet drivers abusing cars here.
    One of our local club members had a mk6 gti with k04 and the valet driver managed to write the car off as he pulled off. He smashed into the back of another car.
    dan1973's Avatar
    OCD clean
    Oct 2009
    301
    Don't take it there for a valet then
    99 Audi a3 tdi sold....
    56 Audi a3 2.0 tdi sline dsg sportback sold
    06 Audi a3 2.0 tdi sport sold
    2001 Audi a3 1.8 20v turbo sport ( new project draining my wallet )
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,547
    Disconnecting the N75 electrically is fine... I drove around for months like it... all the happens is you get an N75 open circuit fault code recorded... if you plan to switch the N75 (which I know Bill has done to the Lupo) then all you will get is this fault code pop up...
    I use my switchable maps to get to an actuator pressure type setting...
    Does depend where your actuator pressure is but on bigger turbos while 12psi can produce nearly 300hp the torque is a lot less so won't feel mega fast anyway
    <tuffty/>
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    878
    Add Vex182 on Facebook
    I have 5 switchable maps while driving and map 1 with the n75 set at 0%, the car is so tame and not eager at all, great around town and gives no fault code too.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Scullies's Avatar
    Feb 2012
    Dubai
    1,253
    How do you switch between maps? Are they activated like the APR system, something to do with the cruise control button, or is it a ecu reflash process.
    I'm guessing each map is a custom tune?
    This might be an option for the BT, when I get round to the rebuilding of the bottom end.
  1. Another n75 question
    By Metro in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th February 2012, 21:39
  2. N75 question...
    By warleydaddy in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2012, 09:04
  3. N75 question
    By AARON77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th June 2011, 13:19
  4. quick N75 question
    By jay1601 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2011, 15:25
  5. N75 Question
    By QuottroA4 in forum Tuning
    Last Post: 6th November 2009, 17:39
