Like Tree1Likes
  • 1 Post By <tuffty/>
Thread: whats most psi i can get from my audi S3?
    Mar 2013
    Blackburn, Lancashire
    17
    Hi
    I got a K04 turbo want to know whats max boost pressure it will take and psi, and what will the bottom end take with out changing anything?
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    879
    Add Vex182 on Facebook
    Standard is 12psi and most remaps tend to push the K04 up to 21/22psi at max boost. No need for any more on a normal standard setup.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    30psi plus but say goodbye to your turbo and power.
    It isnt about boost with a ko4 mate, its about alot more, cooling, timing, air flow, turning the boost up wont make you more power unless dont properly, the ko4's are like ****ing heat pumps.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,569
    If you are considering getting it mapped then it will get mapped to whatever boost makes best power for the condition and level of modification of your engine...
    The ECU's in these cars are load based and you can't tell them what boost you want... a decent tuner such as Badger5 or R-Tech will get the best out of your car whatever your setup..
    Don't get fixated on boost as its not as relevant as people think it is..
    <tuffty/>
    s33nyboy12 likes this.
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    Boost held, boost spike, boost at top end? Audi 8P Ko3's and Ko4's are both not particularly suited to holding any sort of high level of boost at the top end, it results in heat and back pressure. The boost level is related to the resistance of flow in your engine, so depends on mods you have. Don't get too hung up on boost levels, as others have pointed out.
    Ruick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    its easy to turn the boost up, theres a fella in sunderland who can turn your boost up. tuning is easy
  1. what mpg do you all get from your s3??
    By s31urt in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2012, 18:27
  2. BHP torque whats the max you can get out of ko4 turbo
    By S3 GEORGE in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2009, 21:39
  3. How long would it take to get from the Audi Shipping port Germany
    By madalex in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th February 2008, 09:22
  4. Any places in birmingham where i can get my car chipped from 1.8T 225
    By lowrider786 in forum TT/TT-S/TT-RS Forum
    Last Post: 9th November 2005, 14:25
  5. what discount could you get from an Audi dealer
    By darkspin in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2004, 14:35
