Monster MotorsportVolks Autos
Results 1 to 35 of 35
Like Tree1Likes
  • 1 Post By Jason.s
Thread: Engine/gearbox mount fitting guide.........
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    How hard is it to fit the engine and geabox mounts? Is it a on the drive jobbie or a 2 man car ramp job? Also anyone know the part numbers for the mount bolts as ive been told their stretch bolts and should really be replaced!
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,358
    easy as pie mate, 20 mins per side to change tops really.
    Remove air filter / MAF to access the gearbox side one, and the plastic cover on the loom trunking. Support gearbox on a jack, replace mount.
    On the drivers side, remove the PAS res, and I moved the header tank over a bit to gain access, and again, support the engine on a jack.
    Do one side at a time, dead easy.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Definitely get new bolts. Pm Jason for the part numbers as I can't remember them.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Nick do i have to completely remove the pas res or just move it? Dont fancy removing it, also wheres best to support the engine when doing that side?
    jason who westy?
    Westy's Avatar
    Dec 2008
    17,273
    jason who westy?
    Where have you been man?! Jason S. he works at VW in the parts department so obviously has ETKA
    S3 Build Thread
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Ooh yeah sorry mate, forgot he sorted you out with yours haha. Westy do you know what the torque settings are for the bolts?
    May 2010
    Bedford
    2,877
    Stop whoring me out for my services haha
    StaceyS3 likes this.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Haha ive just emailed you mate, hey everybody needs a good whore haha.
    Westy's Avatar
    Dec 2008
    17,273
    Mate, I was pretty much drunk through most of my engine build and I was just reading the torque settings off Elsawin as we needed them so I can't really remember anything
    Hunt around on some torrent sites for Elsawin and get yourself a copy, it's a life saver.
    S3 Build Thread
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,358
    jason who westy?
    Just undo the 5mm allen bolt that holds it in place and move it around to get access to the bolts mate. No fluid lost from anything. I put my jack on the bottom of the sump, on the corner, don't lift it, just take the weight so when you undo the engine mount it doesn't move.
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    534
    thought I'd jump in on this one just a bit I changed my dogbone to a powerflex mount a while back to try and help with the apparent drivetrain "shuffle" during gear changes etc. It didn't help a huuuuuge amount, so I was wondering if I should change the engine mounts also? Would that help?
    Dani; what engine mounts are you going for? Poly or OEM?
    thanks guys
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Just bought brand new engine mounts and going to fill them with liquid poly as recommened my prawn . Should be epic.
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by Squirrelofdoom View Post
    thanks guys
    Maybe your engine and gearbox mounts are badly worn then. The red dogbone bush was really noticeable on my car! I have seen some OEM mounts that can be easily moved by hand they were so bad. Both of mine were still fairly solid when I replaced them for brand new OEM mounts.
    S3 Build Thread
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,358
    did you get genuine ones or just pattern ones Westy? I think I'm going to do what Danny is going, get some brand new standard pattern ones, and poly fill them. Considering Drilling out sections of the rubber too to get more Poly in there for added stiffness.
    Feb 2012
    Surrey
    534
    Cheers guys. Westy, when you say Engine & Gearbox mounts; do you mean just the dogbone and the two side engine mounts?
    Also, color me confused about this whole buying new engine mounts and then filling them with poly....never heard of this done before. How do you go about doing this? Do you have to remove all the rubber?... :S
    May 2010
    Bedford
    2,877
    Think he got pattern parts. I qouted for OEM mounts but he nearly had a heart attack lol
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Where from o mysterious one....
    Westy's Avatar
    Dec 2008
    17,273
    Pattern ones from GSF I think.
    Yeah I meant the 2 side mounts being soft a fook.
    Quote Originally Posted by Jason.s View Post
    Indeed the OEM mounts required a small mortgage.
    S3 Build Thread
    Feb 2012
    Surrey
    534
    Yeah, just had a look at OEM engine mounts myself :0
    I just remembered, I didn't actually change the small bush in the dogbone mount, should probably do that before splashing on new engine mounts just in case. Just seen that Powerflex have this "black series" stuff now - anyone used them yet?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Haha that would be telling dave. Its from ebay but have found it for a fiver cheaper on the interent, do you guys want the link posting?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Yeah Dani... please
    Westy's Avatar
    Dec 2008
    17,273
    Yeah Dani... please
    he's such a little tease...
    S3 Build Thread
    Reesy's Avatar
    East Sussex
    3,604
    I'd be interested in the link , my engine can be moved by hand even when everything is bolted down
    Engine mounts are top of the to do list, but if tiger seal isn't going to cut it then this poly solution looks like a winner
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Here you go, works out at £32 delivered which is a fiver cheaper than ebay: Polytek Poly PT Flex 85 Liquid Casting Rubber - mbfg.co.uk
    You lot love been teased haha.
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Got a fudged set of mounts knocking about if anyone wants them to play with
    Here's a vid of how soft they were and can pull them apart
    http://youtu.be/gQ4BxRc22Z8
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    whats shore 85 in the grand scheme of things? anyone know what shore the purple powerflex stuff is?
    EDIT: their black series stuff is 95. purple is 80.
    its good you found a part poly that lists the hardness. comparing it to the powerflex people can get a good idea of how it will feel.
    I think 85 on a bush/mount as big as the engine mounts will be quite good.
    When i first bought my powerflex bushes i was suprised how soft they were, i expected them to be near plastic.
  28. #27
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Shore 85 i believe is as strong as you want togo, i believe the ths ones are 80, im going for 85 but it does range from 60-85.
  29. #28
    Reesy's Avatar
    East Sussex
    3,604
    Just bought 1kg of the stuff from Dani's link, I'll post up some pics when it arrives..
  30. #29
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Nice one mate, ill be doing the same tomorrow when i get paid. Just ordered all new bolts for the mounts via jase, thanks dude.
  31. #30
    J B
    J B's Avatar
    Dec 2008
    Hants & Ox
    140
    Has anyone done there engine mounts yet and got any pictures?
  32. #31
    J B
    J B's Avatar
    Dec 2008
    Hants & Ox
    140
    Ok I have filled my engine mount and refitted (havnt done the gearbox yet, not sure I want to!) but the vibration is pretty bad, I was wondering if anyone else has done this and had the same issue? I have just fitted a releness mani, downpipe and cat as well as rebuilding an agu cylinder head and reconditioned turbo all on my AMK S3, I'm hoping none of that is causing the vibrations!
    Cheers for any input and here's a couple of pics.
  33. #32
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Hows the car handle and drive with them mate? Whens the vibration noticeable?
  34. #33
    J B
    J B's Avatar
    Dec 2008
    Hants & Ox
    140
    Really bad cabin vibration and rattles from idle-1500rpm, I havnt really pushed the car at all I literally only started it yesterday after spending 6-7 weeks rebuilding everything. I'm wondering if the downpipe could be touching in the tunnel somewhere. And I have only done the engine mount so far, I did the red dog bone bush about a year ago.
  35. #34
    J B
    J B's Avatar
    Dec 2008
    Hants & Ox
    140
    I have done both mounts now and the vibration has died down a bit its just bad on idle really, the other issue I have is that the downpipe now vibrates against the tunnel on coast down mainly so im going to replace them for pattern parts.
    Just one query ECP list engine mounts left and right for APY but only right hand for an AMK are they all the same anyway?
  36. #35
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,270
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by J B View Post
    How many miles have you done on them now out of interest?
    I have clocked up about 500 and it is getting a lot better.....crazy transmission/gearbox sounds....very rally car style and so solid. I have got a lot more confidence in throwing it into corners now with the rest of my set up. Just need her lowered a tad and I think it will be perfect.
    Here's my little write up -
    Downpipe results in replacing my engine mounts
    (sorry can't help you about the question you posted, as I have an APY lump )
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
  1. Engine / Gearbox mount problem?
    By duffy78 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th April 2012, 10:40
  2. Will this fit my S3 gearbox mount??? Audit tt BAM similar to S3 AMK??
    By mrj0ey in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2011, 13:59
  3. Engine, gearbox and diff mount options?
    By camouflage in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th October 2010, 10:04
  4. Timing belt and engine / gearbox mount
    By nky_84 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2010, 21:57
  5. Engine mounts fitted...
    By Geeman in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th July 2009, 14:04
