Sky InsuranceJMB Retrofits
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Rpm surge after release of throttle - any ideas?
    This afternoon, I fitted a used speed sensor of eBay as I crushed the original one while fitting the engine.
    I also replaced the vac lines to the fpr, and DV. The boost gauge is tee'd into the DV vac feed.
    After a test drive, I have an issue with the rpm. It carries on rising after I lift off the throttle for about 1000 rpm then slowly drops down.
    Seems I have invented No Lift Shift without touching the ecu lol
    There is a fault code
    17748 - Camshaft position sensor (G40) / engine speed sensor (G28)
    P1340 - 35-00 - incor. Correlation.
    Do I need to calibrate something with VCDS.
    I had no other faults with the damaged speed sensor when it was electrically disconnected, just a non working speedo and no signal from speed sensor.
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    So this morning I checked the engine timing marks. Crank and cam marks are spot on. Also have 16 chain rollers between the camshaft markings.
    fitted a new camshaft sensor but still have the same problem with the rpm surging after throttle lift off.
    I will try disconnect the engine speed sensor when it's cool enough to stick my hand down there.
    The sensor is working as my speedo is operational again.
    Edit - for being stupid.
    so after some thinking about the speed sensor and how it would be picking up engine speed from the gearbox, I have realised my mistake.
    seems I have been confusing the engine speed sensor with the vehicle speed sensor.
    Engine speed sensor is the crankshaft sensor that picks up a signal from the trigger wheel. Vehicle speed sensor that I replaced is in the gearbox and sends signal to your speedo.
    think I will have a few beers then look at the car again, it might make more sense then lol
  1. Strange vibration under full throttle acceleration. Any ideas?
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2011, 15:21
  2. Any ideas ? Stuttering around 4000rpm when under load/full throttle
    By Nyteryda in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2011, 19:17
  3. 17544 reacurring after remap?any ideas??
    By Jay-a3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2011, 20:31
  4. after remap TURBO SQUEAL, anyone any idea?
    By s3ugly in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2009, 10:35
  5. ia after some 19" porsche cups any ideas where i can get some??
    By grays3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th November 2007, 23:09
