JMB RetrofitsChris Nott
    Apr 2003
    s.wales
    363
    Beeping from somewhere in the back.
    Hi all, as it says, three beeps from the rear of the car after opening the door and getting in. Never had it until this week. Only things in the rear are the Bose amp and sub and central locking.
    Anyone had this ?
    Chris.
    PaulS3's Avatar
    UK
    1,003
    Re: Beeping from somewhere in the back.
    its something to do with the alarm.
    back up battery being flat iirc
    Jan 2005
    Norfolk
    304
    check out the FAQ section - it just means that the alarm back-up battery (for the siren) has got low and has had to pull some charge from the main battery
    Oct 2003
    23
    Had exactly the smae problem a week or two ago- problem solved, thanks!!
