Volks AutosChris Nott
    Mar 2013
    A3 8L wheels and spacers
    ​Hi, i am new on here but i need some advice. I have a A3 8l and i will be fitting a set of BMW mv1 wheels to it. The problem i have got is the wheels on it now have a offset of et38 and the bmw rear wheels have a offset of et50. The adaptors i need to fit these wheels are 20mm wide. I would like 2 know if this is the right thickness to fit these wheels. The fronts have a offset of et47 and will be using the same 20mm adaptors on them, anyone know if i will have any problems with fitting the fronts. Also if anyone has advice about fitting wheels with a offset of et50 to my A3 i would appreciate it..
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,506
    How wide are the BMW rims? The 20mm adaptors will make the rears ET30 and the fronts ET27. I think with the right tyres, they will fit with no issues.
    Mar 2013
    The wheels are 225/49/18 in front and 255/30/18 on rears. Do you think that will cause any problems? And 20mm spacers will work?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,506
    Quote Originally Posted by blakie46 View Post
    I wanted to know the rim widths, 255 rear tyres are not going to fit under the rear arches I think, and it would suggest a wide rim, so 20mm spacers might not be enough?
  1. Wheels / Rims - Sizing and Spacer Advice
    By NME in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th April 2011, 21:57
  2. S4,6,8 wheels and spacer advice
    By brys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th November 2010, 20:54
  3. 19" WHEELS AND SPACERS
    By CMD in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th February 2010, 18:44
  4. 17" Avus OEM wheels and tyres for sale
    By pure in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 21:18
  5. Wheels and Spacers
    By mramage in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2003, 16:16
