Badger5JMB Retrofits
Results 1 to 8 of 8
    Mar 2013
    Blackburn, Lancashire
    17
    loss of power in higher gears under load
    Hi Everyone
    When changing
    gear from the top end of 3rd gear to going into 4th, loses power. well that what it feels like. all the way up to aprox 5200rpm then mass boost is delievered.
    do you think it could be the actuator?
    turbo does not have viens and is not smoking or rattling so not turbo?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Slipping Clutch?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,558
    Any fault codes? if the actuator was faulty you would most likely have all the boost and the fault would affect all gears... very much doubt its the issue...
    <tuffty/>
    Mar 2013
    17
    don't think its clutch as feels more like loss of boost. There are no fault codes coming either.
    RIP S3dave
    May 2004
    nr Glos
    7,166
    logs would be helpfull
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Dec 2011
    630
    Could it possibly be heat soak ??
    Mar 2013
    17
    wot is heat soak?
    RIP S3dave
    May 2004
    nr Glos
    7,166
    its like LOGs only hotter
    Seriously tho, do you have facility to vcds ay logs as without some data, its at bets poke and hope advise you will ever receive
    www.badger5.biz
    bill@badger5.co.uk
  1. Loss of power 4th & 5th gear around 1800rpm - Limp mode??
    By ruffrida in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2012, 02:30
  2. A3 2.0 TDI 140 BKD Juddering 5th/6th Gears under load
    By a3sportback54 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd October 2010, 11:13
  3. Loss of power under load, blue smoke, VCDS codes.
    By SAiLO in forum VCDS (formerly VAG-COM) forum
    Last Post: 30th April 2010, 07:38
  4. Loss of power under load, blue smoke, VCDS codes.
    By SAiLO in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th March 2010, 17:58
  5. Power loss under load (TDi 130)
    By smo in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th October 2008, 14:03
