Chris NottBadger5
Thread: boost leak 1.8t
    Mar 2013
    19
    boost leak 1.8t
    Hi, i have 51 plate a3 quattro 1.8t remaped to 220 bhp an some times my car seems to feel like its loosing power after 5000rpm and then sometimes its fine , i keep hearing a hissing noise some times around drivers footwell an then goes i dont know weather its anythink to do with loss of power, any one have any ideas?
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    872
    Add Vex182 on Facebook
    Have you had look in the DV area? Should not be much in the drivers footwell area for boost related stuff. It could also be the map is not 100% right.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Quote Originally Posted by Vex182 View Post
    Its a K03 bud... the boost pipe goes down the back of the engine and onto a pancake pipe that runs along to the SMIC in the bumper area (drivers side)
    They use a bayonet fitting and typically fails at that point... I would imagine the leak is coming from that area
    <tuffty/>
  1. Boost Leak
    By welshdragon in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th June 2005, 15:17
  2. Oil/Boost Leak
    By chimmo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2005, 10:48
  3. more boost leak possibilities....
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2005, 14:23
  4. Follow up from Boost Leak
    By StevieBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2004, 13:43
  5. Boost Leak
    Last Post: 8th December 2004, 20:47
