EM TuningBadger5
Results 1 to 9 of 9
    Jul 2005
    Manchester
    26
    ESP/ABS Error Code
    Hi all
    I have an ESP/ABS fault (both lights come on and stay on until ignition is turned off), I recently plugged the car into my m8s VAGCOM
    It came back with error code 04FF a longitudinal acceleration sensor.
    I've tried doing a search but nothing matched.
    I was just wondering if anybody knows anything about this sensor, or have come across this problem in the past, wouldnt mind knowing what kind of damage Im looking at
    Any help would be greatly appreciated, I dont even know where it is [img]/ubbthreads/images/graemlins/noidea.gif[/img]
    Cheers BD
    Jun 2003
    133
    Re: ESP/ABS Error Code
    Hi m8
    Had the same lights on recently but fortunatly it was a brake sensor and cost about 6. When i was investigating the problem i came accross the longitudinal sensor and i think they are quite expensive. For some reason 700 rings a bell hope im wrong. Not sure where they are located.
    Khufu's Avatar
    West coast of Scotland
    5,693
    I too remember a post about it, iirc there are two one expensive and the other astonomical! IIIrc too, one is located behind the centre console, not sure as I only have ABS not ESP
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    i think you will find it under the back seat in the middle
    Jul 2005
    Manchester
    26
    I feel sick all of a sudden [img]/ubbthreads/images/graemlins/vomit.gif[/img], lol
    Thanks guys, first I just need to find where the sensor is hidden so I can test them with a multimeter, don't fancy going to a dealers, so they can have my pants down, just yet.
    Im told there are 2 of these sensors.
    Jul 2005
    Manchester
    26
    Thanks Pete, will have a look for it
    Aug 2003
    North West
    118
    BoyDave
    Check out the following links for you
    tt forum link 1
    tt forum link 2
    tt forum link 3
    Yaw sensor thread - attachment from khufu for ESP
    By the looks of the info from the tt forum guys, the combined yaw and acceleration sensor located in the steering column is the horrendously expensive one. The longditudinal one is behind the glovebox area (i think) and looks like its about 80ish.
    HTH
    Jul 2005
    Manchester
    26
    [img]/ubbthreads/images/graemlins/woohoo.gif[/img]
    Thanks very much m8
    you were spot on, its behind the glovebox [img]/ubbthreads/images/graemlins/bravo.gif[/img]
    nicksthebiz's Avatar
    Nov 2012
    Hayle, Cornwall, UK
    163
    having the same problem does anyone have the part number for a longitudinal accelerator sensor ??
    cheers
    S3 8L 2000 APY (bens S2000 Air Filter In October 14 Plus V3 B5 Tip Stage 1)
    Nick Jones,Cornwall UK
