Chris NottSky Insurance
    Mar 2013
    please hlep? can anyone tell me how to set the timing on the cam belt what marks etc
    hi ive bought an a3 quattro 1.8 20v t ary engine as a non runner! the cambelt has lost its tension and i suspect that the belt has jumped round on the pullys etc can anyone tell me where to look for timing marks etc to reset it so i can check compression to c if there are any bent valves
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    TDC can be determined the old fashioned way with a long (not sharp pointed) implement done the plug hole of cyl 1.. there is also a bung on the gearbox that can be removed to see a timing mark on the flywheel
    Cam sprocket has a notch in it that can be aligned with a notch on the cam cover... you need to remove the plastic cam belt cover to see this...
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
  1. Can anyone tell me about this set-up?
    By Gaz_Bournemouth in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2009, 07:53
  2. Can anyone tell me how to replace g81 sensor
    By drnutta in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th March 2009, 12:45
  3. Can anyone tell me what these fault codes are please?
    By cha1n in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd July 2006, 13:16
  4. Can anyone tell me how to report an Ebay listing?
    By Nessy in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th February 2006, 09:29
  5. CAN ANYONE TELL ME WHAT WHEELS WILL FIT MY CAR?!
    By claire in forum Classic Audi Forum
    Last Post: 9th April 2004, 13:39
