JMB RetrofitsEM Tuning
Results 1 to 7 of 7
    Jan 2013
    17
    235/45/17 TT alloys on A3 8L?
    Hi all,Had a quick search but couldn't find a definitive answer.Would 235/45/17 audi TT wheels and tyres fit ok on my A3 8L?PCD is 5x100 so I know that's ok, I'm more concerned about rubbing etc etc...Thanks!
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    234/45 is too big a profile so your speedo would be out.
    if you're lowered considerably it may rub, depends tho
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,374
    Speedo difference is so marginal you can 100% ignore it,
    standard tyre size is 205/55/16, total diameter 631.9mm, 235/45/17 has a total diameter of 643.3mm.
    The speed will in theory under read by just 1.8%, but seeing as all speedos over read by 5-10% anyway it'll actually make your speedo MORE accurate, not less
    I run 235/45/17 on mine and have no clearance issues at all.
    Feb 2011
    Leeds
    176
    I ran 235/45/17 on my TT wheels. I had no issues and my car is down on coils. Dare say handling was a little better over 225's
    A3 TDi 196 Bhp 340 ft-lb
    The Build Thread
    Darkside Map, PD150 turbo, Allard FMIC, SFS Outlet pipe, Polybushed, Forge Short Shift , LCR Brembos, 17 TT Comps, AP Coilovers, S3 Recaros
    Dec 2011
    396
    i run 235,40,18s with a 32mm offset had to space the front due to being proper low
    Jan 2013
    17
    so in your experience would you say im better off leaving it at stock height or lowering it? if so how much should i lower it by so that it looks good but is minimum fuss.....
    Dec 2011
    396
    well mine is so low you can just about put a finger between the tyre and the arch so fit them and play with the hight
  1. 235/35/19 are they right for 8.5j alloys?
    By allyp in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th February 2011, 15:14
  2. Alloys 5x100 235/35/19.... would it fit?
    By HSerce in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th October 2009, 19:39
  3. S3 ALLOYS ??
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2003, 16:47
  4. NO NO NO.... Just scratched my Alloys
    By Chimera in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2003, 16:40
