Chris NottSky Insurance
    Scullies's Avatar
    Feb 2012
    Dubai
    1,255
    Non turbo FSI crankshaft good for stroker build?
    As above I was wondering if a n/a 2.0 FSI crankshaft would be suitable. All the info on stoker builds are referring to TFSI cranks. Not sure if there is a difference between FSI and TFSI crankshafts. The crank I have found doesn't look the same as the TFSI I had before. It's looks more like the 2.0 8v crank used in the mk4 engines, so I am assuming its cast.
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,470
    Mines cast and its still mint, the yanks are running cast cranks with a hell of a lot more power than me. I will get the engine codes of cranks you can run for a stroker .
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Scullies's Avatar
    Feb 2012
    Dubai
    1,255
    Thanks Andrew,
    I see the Yanks go on about the AEG crank! Do you know what is so special about that crank. As far as I can see all 2.0 8v and 2.0 fsi cranks should be a drop in crank for a 2.0 stroker, excluding the oil pump drive gear on fsi crank.
    Scullies's Avatar
    Feb 2012
    Dubai
    1,255
    I think I found your list on vortex
    VWVortex.com - 2.0 stroker crankshaft options
    this makes my life easy now, there are so many mk4 engines in the scrap yards here. 2.0 8v and 1.8 20v. They get cut out cars in Japan and shipped over by the container loads!
    Jun 2009
    Leeds
    3,470
    That's the one I was looking for
    FOR SALE
  1. 2008cc 20 Valve Turbo Stroker Build
    By IN 2 Deep in forum The Project Room
    Last Post: 29th November 2012, 21:11
  2. A4 B6 turbo - Any good for a B5?
    By Oranoco in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd June 2008, 13:39
  3. Any good resources for Audi build process info?
    By A3_TOBES in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th September 2006, 13:32
  4. Turbo add on for non turbo A4 1.8
    By imported_bearboy in forum Tuning
    Last Post: 9th September 2004, 14:18
  5. Air Filter for my A3 1.8 sport (non turbo)
    By imported_reda3lee in forum Tuning
    Last Post: 30th August 2004, 10:14
