    Jan 2012
    powys
    46
    Question pd 150 not boosting until 2000rpm runs out at 3000rpm
    hi girls and guys i hope you dont mind me joining in i have a mk4 golf gtpd 150 , my wife is on the 8p forum she has a 3.2 v6 dsg.
    the issue that i am having is that when brought the car it had no boost , and what i have done so far is to remove the egr cooler , then mr muscle the turbo , now i have boost .
    the turbo was replaced 2 years ok , could it be my maf or map , i have cheaked for leaks , so i thinck next i will replace all my vaccum hoses .
    thanks ray
    Jan 2011
    northants
    165
    get a diag test done and check maf in data to see if its working
    dan1973's Avatar
    OCD clean
    Oct 2009
    301
    Like said get it scanned, but I had a pd150 bora previous to the Audi and it had the same symptoms as yours and turned out too be the maf.
    99 Audi a3 tdi sold....
    56 Audi a3 2.0 tdi sline dsg sportback sold
    06 Audi a3 2.0 tdi sport sold
    2001 Audi a3 1.8 20v turbo sport ( new project draining my wallet )
    beachbuggy's Avatar
    Surrey
    1,727
    Quote Originally Posted by donna View Post
    thanks ray
    VNT stuck. Trying moving it manually if that fails check n75
    Jan 2012
    powys
    46
    thanks guys will get codes read. atuater moves ok while by hand. not checked function while running using vaccum
    May 2012
    RETFORD, NOTTS
    1,706
    Just take the turbo off and post it to me, i wont fix it or pretend i can, but i have no money and realllllly want a 150 turbo for my A3 :D
    Sorry, i cant find them second hand anywhere, so thought id jump in on the first mention of a 150pd on here to express my needs :P
    Does sound like a MAF though, a few logs on vcds should tell for sure.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. What to get fixed before the warranty runs out
    By ollyhawkeye in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th January 2010, 09:47
  2. What Happens Once You Run Out Diesel...
    By emzino in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th March 2009, 13:00
  3. 3.0 misfire problem - running out of ideas...
    By amiller001 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th January 2008, 16:15
  4. A4 run out special offers!
    By gizze in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th February 2007, 15:27
  5. Chipped T Sport owners. What Bar/Psi Boost are you running?
    By sfource in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2005, 00:24
