Badger5Sky Insurance
Results 1 to 7 of 7
    Oct 2012
    234
    S3 dump valve question
    Hi, so bear with me here as im a turbo newbie. My S3 currently chatters, which i think is the result of the dump valve being in backwards? Or possibly the N75 being deleted? Im not sure... But its got the standard dump valve in place, n249 bypass. So i want to get rid of the chatter as its not good for the turbo i hear. So should i be looking to replace the standard dump valve with a Forge item? If so what are the advantages?
    Engine spec; APY, stage 1 remap, FMIC, forge TIP.
    Thanks in advance
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    If it makes a chattering noise then its likely the DV is faulty and needs replacing
    <tuffty/>
    Oct 2012
    234
    Oh right is it? Someone looked at it and thought the Dv was backwards. So could try turning it round and seeing what happened? Is it worth getting a forge dump valve or divert valve?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    Pics would help and maybe a video of the sound....
    OE valve is perfectly capable of doing the job... up until recently all aftermarket valves leaked to a degree (OE doesn't) but Forge have recently upgraded all theirs and now leaks are pretty much non existent... you don't need to 'upgrade' as the OE valve holds 30psi and is a good enough valve but the Forge ones last longer (still need a service once a year with new o-rings and silicon heat resistant grease, they do a cheap kit) and of course they are engine bay bling...
    If funds are tight then replace with OE, if you have some cash burning a hole in your pocket and fancy the bling then get a Forge 007 or 008... DON'T buy a Split-R or any other type of atmos valve as VAG ecu's do not run well with them
    A couple of useful threads
    I stripped my Forge DV down as i wasnt sure if it was leaking... Advice needed please
    Interesting Dump Valve Information For New Buyers And Owners. Servicing Etc
    <tuffty/>
    Oct 2012
    234
    Thanks very much mate ! Think ill stay oe.
    Forgot to say, had the exhaust manifold replaced yesterday as mine was cracked and my mate said the n75 was deleted. What exactly is that doing? Or not doing as the case may be.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    N75 deleted? I hope not lol... thats the boost control valve.... he either has no clue what he means or you are in trouble
    Picture of the TIP area will help settle this but I suspect he means the N249 delete... this is the valve that the ECU uses to dump boost via the DV if there is a problem
    <tuffty/>
    RIP S3dave
    May 2004
    nr Glos
    7,131
    80mm TIP is what you want if shopping for one of these
    link in my siggy
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  1. Dump Valve question
    By audi_a3_turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th June 2011, 10:17
  2. Dump Valve Question 1.8TQS
    By muz_amin in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th November 2009, 21:20
  3. another dump valve question
    By peakey in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2009, 14:34
  4. Dump valve question!!!
    By fataudifella in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2004, 18:57
  5. yet another dump valve question!!
    By spencerjoel in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2004, 08:11
