Badger5EM Tuning
Results 1 to 7 of 7
    millsy75's Avatar
    Dec 2012
    192
    climate control part numbers
    Hello everybody.
    I'm looking for a bit of help with climate control part numbers.
    My current climate number is - 8L0820043K
    I'm looking to buy 8L0820043H. Will it fit OK and connect up at the back?
    Visually mine is the lighter black/grey soft rubberised type and the other part number is the black hard plastic (harder to scratch!).
    Also if I decided to fit sat nav RNSE? would I need to change the climate unit again?
    Thanks for any help :-)
    millsy75's Avatar
    Dec 2012
    192
    Bttt
    millsy75's Avatar
    Dec 2012
    192
    Monday up
    Cobra88's Avatar
    Sep 2011
    Live in Ipswich Suffolk (orig from W London)
    431
    Hi Mate
    yes both have same connetions and fit above the cubby hole unit.
    all facelift climate units have same connections
    if you fit a double din you can just trim the climatevsurround using a template made from the cubby hole door
    or just buy a double din climate unit off flebay
    Regards
    Rick
    2004 Audi A4 (B6) 1.9Tdi 130 Sport (6) Avant in Dolphin Grey.
    18" S4 AVUS, RS4 Rear Roll Bar, Leather Alacantra Sport Seats, Shark Performance 170 Remap,
    BOSE, XtronsA4A double din, Full DIS, Autolocks & Alarm Chirp.
    Avant Sport 1.8T Valance with twin exit.
    millsy75's Avatar
    Dec 2012
    192
    Hi mate, thanks for your reply. Am I right in thinking there are single and double din climate units? Single din being smaller and double din double the size??!
    Cobra88's Avatar
    Sep 2011
    431
    Hi Millsy
    Both similar size
    Double din one fits lower down
    Facia can be swapped from one to another with small torx screws holding facias on.
    the part behind the facia is the same on both units, just the facia is different.(Visually at least)
    I just swapped mine when i wired up my heated seats
    Double din ones tend to be £80-100 on Fleabay
    Normal single din are about £20-30 and easy to trim if you use the cubby door as a template
    Depends how handy you are really
    Regards
    Rick
    millsy75's Avatar
    Dec 2012
    192
    Thanks Rick, interesting info :-)
    Have you converted your seats to heated ones?
  1. Climate control part number
    By morgan306 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st July 2012, 00:37
  2. Retro fitted RNSE on 2004 8P 3.2....what climate control part number do I need?
    By golfg6076 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st August 2010, 16:35
  3. Cruise control part number
    By Ryanmt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th June 2010, 10:30
  4. Cruise Control part numbers
    By Nickynibbles in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd March 2008, 18:49
  5. Cruise control part number?
    By awmw in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st December 2006, 19:09
