Monster MotorsportChris Nott
    May 2012
    Barry, Vale of Glamorgan, United Kingdom
    55
    s3 8l turbo oil pipes diagram
    hi all.
    has anyone got a parts diagram for a 1999 apy engined s3.
    i started the car this morning with the bonnet open, there was smoke coming from the turbo area. i think there is oil getting onto the turbo/manifold some how.
    i did have a quick look. but had no mirror available to look closely.
    any ideas?
    thanks.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,444
    It will be leaking from the cam cover gasket... they all do it... new cam cover gasket set required... just under 20 quid... also the 1/2 moon seal thats under the cam chain tensioner... these shrink and go hard and oil leaks from there too... there will most likely be oil all down the side and back of the head...
    <tuffty/>
    ShaunS3's Avatar
    Yorkshire & Humber Rep.
    Mar 2012
    West Yorkshire
    876
    Re: s3 8l turbo oil pipes diagram
    Quote Originally Posted by ;1811490
    <tuffty/>
    Hmmm....goes to check the weaping oil on my cylinder head
    May 2012
    55
    Cheers will have a good look in the morning.
    Thanks for the advice.
  1. Turbo oil return pipe removal.
    By philpy in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd October 2012, 13:59
  2. Turbo oil return pipe
    By Lemon S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2012, 15:37
  3. Turbo oil pipe
    By HOTTIGGER in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2012, 18:42
  4. turbo inlet oil pipe?
    By Kingfisher in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th October 2011, 17:53
  5. Oil in Turbo charge pipe
    By rob1380 in forum Diesel forum
    Last Post: 31st May 2007, 18:21
