Badger5Monster Motorsport
Results 1 to 9 of 9
    May 2012
    RETFORD, NOTTS
    1,753
    No bonnet open warning?!Wiring diagram please for clocks/locks
    As above, I know danio supplied me some but i cant for the life of me find them!
    I am finally getting around to fitting my bigger washer bottle and low warning, but tonight the alarm was playing silly buggers.
    The bonnet up warning on the dash has never worked as far as i know, but the dash was from another car so i think maybe the wires are a little different, I had to use VCDS to find the fault that the car should be capable of displaying i think!
    Clocks are from a 2002 tdi quattro. Door open warning works fine.
    Is there anything else that manages these warnings?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    886
    Add Vex182 on Facebook
    My car does not show when the bonnet is open, unlike the doors and boot, is it supposed to?
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    May 2012
    RETFORD, NOTTS
    1,753
    I just assumed it was, and if it does then this would have saved me pulling the vcds out !
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    Yeah there's no bonnet open warning. If the bonnet is opened whilst car is alarmed it will trigger it though.
    May 2012
    RETFORD, NOTTS
    1,753
    It was bizaar, it must have opened in the cold after a long run this afternoon. Then the alarm went off, and it wouldnt re arm, only ever did this before when i had an iffy door switch. Ive just unplugged the bonnet switch for now.
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    355
    its a shame there is no warning on the dash that the bonnets open, that would be nice. aparently the switch it supposed to stop the wipers from working when the bonnets open
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    187
    Hi after a long break.There is a bonnet warning lamp on dis and it can be connected however now it is not wired up to the clocks. It must be something different that trigger your alarm.Still need those diagrams???
    Currently not in the country
    May 2012
    RETFORD, NOTTS
    1,753
    Quote Originally Posted by Danio View Post
    Sure danio, would be awesome, how much extra work to wire the DIS warning in? is there a contact already on the loom or is this needing a new wire from the bonnet switch? Do you know the pin number on the cluster?
    Im also thinking about wiring in the lamp failure warnings too, any info on those or could i just make up a simple controller and output to the clocks?
    It was defo the bonnet switch caused the alarm, vcds told me so :P
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    187
    Right pin for the bonnet on the cluster is 25 on the green socket.
    Sensor from the bonnet lock already should be wired to the scuttle panel but I don't remember which pin is that, however will let you know on Saturday.
    To fit warning light system I have to say it is not an easy job. First just have a look under a steering wheel where all relays are for relay number 381 or just make me a photo. You might have it all system already on the car.
  1. Headlight/lamp wiring diagram please (:
    By James TQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th June 2012, 01:12
  2. A3 BONNET OPEN WARNING
    By JonRola in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th April 2011, 01:24
  3. Bonnet open warning came on "at speed"
    By PetrolAholic in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 31st January 2011, 10:55
  4. wiring diagram for dimming mirror please
    By rasA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd April 2010, 13:30
  5. Wiring diagram for an S3 (02)
    By Mattytay in forum General Technical / How To
    Last Post: 1st March 2005, 20:40
