Volks AutosMonster Motorsport
Results 1 to 9 of 9
    Mar 2013
    12
    flat as a pancake
    hi all. enjoying my recent purchase of my 2000 a3 1.8l. got a few issues such as a lack of pad on rear discs but fitting newnew ones tomo. but it seams to have another prob its flat when giving it the beans , but not all the time. new filters and plugs is my first point call but wonder if there maybe a common fault of issue.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    828
    Add Vex182 on Facebook
    Coilpacks, boost leaks and blocked fuel filter would be a good place to start too.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Mar 2013
    12
    full on service needed then. also has high bite on clutch. but clutch seems bang on. stretchy cable perhaps or are they usually pretty goodgood
    Lewis583's Avatar
    Mar 2010
    836
    The clutch is hydraulic operated so no cable to stretch. What's the mileage? More than likely just worn.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Feb 2012
    733
    would a maf not be suspect? if its flat but jot all the time?
    Mar 2013
    12
    hm is the maf flywheel associated or an abrevation for something else. nope not flat all the time. took for decent drive today was great awesome car feel connected to the road. but was not flat all the time
    Feb 2012
    733
    maf is the air flow meter. they go a lot and can make the car seem sluggish. is your car a turbo?
    Mar 2013
    12
    what a nob of course thats what i means i should know this stuff. and no not turbo but want to induct was going to as about sensors if i needto be careful when doing this mod. but sort this prob out first
    Mar 2013
    12
    on driving to itloved the cold air think your diagnosis could be right she was flying at 3rpm then flat then picked up the flat then stayed quick well for non turbo
  1. Drivers Seat "wing" Flat As A Pancake!!!
    By phoenixv6quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th June 2011, 19:07
  2. S3 flat spot?
    By azures3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th May 2004, 07:28
  3. engine goes flat at 3000 revs
    By ratty in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd May 2004, 02:21
  4. HELP Flat spot in low RPM, looking to boost it up
    By burts90Q in forum Classic Audi Forum
    Last Post: 15th March 2004, 22:39
  5. Flat spot @5prm in 5th and 6th
    By WRN in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2003, 16:29
