AH FabricationsVolks Autos
Results 1 to 11 of 11
    James TQ's Avatar
    Apr 2012
    Essex
    546
    Broken down need help ASAP
    Driving along all was fine, clutch went half down stuck there then went full down wont come back up, pulled it up gently and a white clip pinged off when the pedal lifts up it locks up and the if you press down it snaps down and stays down. Any ideas to start looking whilst I'm waiting for the aa? Thanks guys
    Lewis583's Avatar
    Mar 2010
    833
    Sounds to me like the pedal is no longer connected to the master cylinder, either pivot end of the master cylinder is broke or the pivot/pedal is damaged. Only way to know for sure is to stick your head under the dash and have a look
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    Yep... std clutch pedal fail... little metal plate on the back of the section the clutch master cyl attaches to the pedal is held on with spit... this pops off and the white plastic clip goes through resulting in the pedal staying on the floor
    <tuffty/>
    James TQ's Avatar
    Apr 2012
    Essex
    546
    That's the one tuft. The white clip come out when I pilled clutch up getting recovered now he said there's no leaks and the push pin isn't going into the cylinder he said could be seals, if I look and it's the same as that pic what part do I need to buy?
    looks like I'm not getting my tattoo tomorrow, money going to be spent on the car...again!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    if the clip has survived and the little metal plate has been recovered then you could just have the plate welded back onto the pedal and all will be good in the world else its at the least a new clutch pedal and the worst a new clutch MC...
    <tuffty/>
    James TQ's Avatar
    Apr 2012
    Essex
    546
    Got it home it is indeed the ball joint bit, sigh of relief, put a bolt through it and all is well so will be off tomorrow to buy a new clutch pedal, anyone know how much they are as I can't find the on euro car parts?
    Thanks for the prompt replys
    May 2012
    RETFORD, NOTTS
    1,706
    There was an 8L breaking posted a little while ago, wonder if he would be able to take it out pronto for you?!
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    James TQ's Avatar
    Apr 2012
    Essex
    546
    Ill have a butch, thanks. I found part number but I need to find one tomorrow as I stuck a Allen key through the pedal not the safest hold but there you go... Any idea how much audi would charge?
    James TQ's Avatar
    Apr 2012
    Essex
    546
    Would a mk4 one fit?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    AJC
    AJC's Avatar
    Surrey
    170
    Quote Originally Posted by James TQ View Post
    Hi James, have a read of this:
    Replacing broken clutch pedal (how to with pics)
  1. need help asap! about my lowered a3
    By audi-tk in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd October 2010, 20:14
  2. Guyss A friend needs help ASAP
    By Azizur_Rahman in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd August 2010, 00:14
  3. i need help asap
    By chris1988brown in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2010, 22:31
  4. NEED HELP ASAP
    By Andywilliams1977 in forum General Technical / How To
    Last Post: 31st August 2007, 17:59
  5. REALLY NEED HELP - ASAP
    By jazzyc in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd June 2007, 18:25
