Badger5AH Fabrications
    Mar 2013
    Side indicator bulb and wiring missing!! 99 S3
    Hi people,
    Purchased my Cactus Green S3 two weeks ago!!!
    Loving the S3 life, but had the bulb error flash this morning, checked all me lights and noticed the passenger side indicator wasn't working.
    After further inspection the cover popped out with a load of ancient rubber bands holding it in, and typically no sign of the bulb unit etc.
    What's the best and cheapest way to get this sorted? I assume someones had issues with the unit before so bodged it back into the panel when the clip has snapped off. Obviously i can grab a cheap cover to replace that, but how do i go about finding the wiring and bulb unit inside the bodywork!!?
    J
    mark_S3's Avatar
    Yorkshire & Humber Events Rep
    Sep 2012
    Wakefield
    600
    Presuming the wiring and bulb holder has fallen down back of wing.
    Would suggest making a long hook out of metal rod/hanger and do a bit of 'hook a duck' through the cover slot for the wiring.
    If not undo the wheel arch liner and find it that way.
    ***2000 Audi S3 8L APY***
    * Milltek CATback * Milltek 200 Supercell Sports CAT * SuperChips SPS Stage 1 Remap * Forge 008p *
    * 18" Audi TT 240 Sports Alloys in Gunmetal Grey * Pagid Discs with BD Predator Pads *
    * Badger5 v2.2 TIP, JR Filter with Heatshield * N249 Delete * N112 Bypass *
    * PowerFlex ARB Bushes * TFSI Coilpacks * Saikuo Michi S3-OCC *
    * PowerFlex Rear Engine Mount Bushes *
    [IMG][/IMG]
    Mar 2013
    Yeah i reckon so, if i can't get it like that (assuming there's a chance its not there or could have been missing a good while judging by the ancient lacky bands) is it easy to get the liner off?
    J
    mark_S3's Avatar
    Sep 2012
    Wakefield
    600
    Haven't personally done it myself on my S3 but have done on other cars.....
    Usually a few screws either posi drive or star shaped screws to undo arch liner. Easy job to do. Might be worth whipping wheel off aswell to make it easier for liner to come off. If not just loosen arch liner and place your hand down back of it to feel wiring.
    [IMG][/IMG]
    Mar 2013
    Nice 1 cheers,
    I'll nip out at lunch and shine the flash light in to see if i can spot it and then start my metal hanger construction
  1. replacing side indicator bulbs on wings plus a surprise
    By danger S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2012, 19:25
  2. How do you change the passenger side indicator bulb?
    By jonnycraig in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th May 2011, 17:48
  3. Trying to change side light bulbs and fog light bulbs
    By tmcentee525 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd March 2010, 11:54
  4. how do i get the the indicator bulb front and back
    By rockstar in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th July 2004, 16:18
  5. S6/A6 side indicator bulbs
    By Kevshann in forum General Technical / How To
    Last Post: 7th July 2003, 19:00
