Volks AutosMonster Motorsport
Results 1 to 7 of 7
    Jul 2011
    42
    Internals needed to achieve a reliable 350hp on an AMK code motor??
    Hi, i'm just after a bit of advice off people who have achieved the 350hp mark in their s3's and basically the sort of internals that are good for the job. I'm aware that the stock rods are choclate, as the spare engine I origanally removed from the car failed due to a rod! But what else apart from rods is needed to make a pretty strong everyday 350hp motor? Your comments and views would be much appreciated!!
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    829
    Add Vex182 on Facebook
    Hey, this is a good place to start Lots of Big Turbo and High Power info!
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,084
    Depending on turbo choice, and the revs required to meet your goals, many would argue that rods are the only internal mod required for a 'safe' 350bhp.
    The limit of the stock valve train is said to be 7800rpm, so if you can reliably and safely achieve your 350bhp before 7800rpm then rods and a well built engine are what you need.
    If you like corners and cornering then a baffled sump is a good buy to protect your investment, build the engine well, replacing things like the oil pump and rings that people often don't bother with, and bolt in a good clutch that will cope with the torque you're expecting, and you should be good to go.
    Internally, all mine has is forged rifle drilled rods on a tuffty-Built lump and a baffled gated sump, it's the ancillaries that get you the power
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Biggest issues with std valve train is guide wear... guides on 20v's can wear quite badly which is fine for normal rev limits but at higher limits the valve will wobble about a lot more and not seat right with the potential to knock the heads off....
    <tuffty/>
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,084
    I'm wondering if this will be an issue for me Paul, considering my engine spends a LOT of time between 6-7k!
    www.badger5.co.uk
    May 2004
    nr Glos
    6,952
    rods and new shells all you need as a minimum.... and of course a suitable turbo setup to deliver the power.
    fuel pump is on the edge of being adequate for this power so consider one of these also, and injectors etc etc etc
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Jul 2011
    42
    Thank you for the input guys, atleast now I know what to start with! What kind of turbo set up would be fairly healthy for this figure??
  1. What internals can you improve a k04 with before you need to machine it?
    By slowcoach3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th January 2013, 18:27
  2. You will all need to reregister!
    By Ads in forum General Chat
    Last Post: 13th December 2010, 17:58
  3. Reliable Garage needed for Service (near Staines)
    By Peety in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2009, 14:44
  4. Who needs Coil Packs?
    By NeuSkoolA3 in forum General Chat
    Last Post: 25th January 2003, 13:50
