Sky InsuranceAH Fabrications
Results 1 to 12 of 12
    martin_can's Avatar
    Nov 2012
    13
    Loose power on high revs
    Hi I am new here i got a 2002 s3 225 first and second gear is fine but the third gear soon as It goes over 5500 rave it starts hesitating it is the same as the 4th 5th and 6th gear I changed n75, n924, and mass meter now it's ok up to third gear then it starts doing it a little bit on fourth gear but its still bad on 5th and 6th gear I'm running out of ideas there's no foult code on the vag com please help!
    Mar 2010
    Durham NE
    575
    i had a similar fault once i had my car mapped,after changing everything ! and getting no were i change the fuel pump for a spare i had...bingo,you could try checking your fuel pressure if you have the kit?
    James
    Silver Audi 8L S3
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    and many many cars and bikes in the past!!
    martin_can's Avatar
    Nov 2012
    13
    Thanks for the reply that's the only thing left to change do you have any idea how much are the fuel pump. I did a boost leak check and it was nothing wrong with it could it be the coil pack ???
    Mar 2010
    Durham NE
    575
    i replaced all four of my coilpacks with genuine when i had my fault,as you... done it all bar the pump,the pump i got was used and around 30 quid
    James
    Silver Audi 8L S3
    Mar 2010
    Durham NE
    575
    does your car start from cold first time or on second turn?
    James
    Silver Audi 8L S3
    martin_can's Avatar
    Nov 2012
    13
    It always starts first time cold or hot but when it's very cold and when I start it raves jump up and down a few seconds and then it's fine before the remap it wasn't very noticeable after a remap you can really notice it
    Mar 2010
    Durham NE
    575
    i would defo think the pump is old...
    James
    Silver Audi 8L S3
    martin_can's Avatar
    Nov 2012
    13
    Ok thanks for your help I've got work tommorow so first thing Thursday morning ill change it and see what happens fingers crossed !
    Mar 2010
    Durham NE
    575
    you mentioned after and before map...was before the car fine before the map?
    James
    Silver Audi 8L S3
    martin_can's Avatar
    Nov 2012
    13
    It was still doing it before the remap but it was very slightly and not very noticeable but after it is very noticeable and it feels like the rave limiter cutting in
    Mar 2010
    Durham NE
    575
    that was just like mine bud,fine before map..after all the trouble started,swap the pump over and let us know the outcome bud
    James
    Silver Audi 8L S3
    martin_can's Avatar
    Nov 2012
    13
    Ok I will
  1. S4 white exhaust smoke only at high revs
    By sun and kath in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th June 2007, 20:41
  2. Annoying High Revs!!
    By J7USS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th April 2007, 22:27
  3. noise at high revs??
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2006, 17:29
  4. Loss of power at 2200 revs.
    By doeboy in forum General Technical / How To
    Last Post: 25th May 2006, 23:10
  5. Power loss at high revs
    By imported_alecblack in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2006, 12:39
