EM TuningChris Nott
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By MURRAYS444
Thread: Can someone help tell me if this noise is good or bad video attached
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    Hi had a funny noise when I press the accelerator in my car I have the badger 5 TIP and the jetex cone filter my car is a 2003 S3 8l bam engine hope the video helps the car feels fine under boost if thats any help
    007-5_zpsb8241b98.mp4 Video by scottm4 | Photobucket
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    That is the sound of a buggered DV or one thats lost its vacuum... what DV you got?
    <tuffty/>
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    Ah was thinking it could be the DV sticking I have a forge 007p one mate
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Worth checking it then as they need a service from time to time... what spring is in it?
    <tuffty/>
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    Not to sure as I haven't had it apart I have a yellow spring kicking about, i'll give it a good service as I fitted it over 3 years ago
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Leave the green in if you have it... stiffer spring will make it worse... Forge sell service kits and if you have an early 007p then get a kit with the new revision of piston that has the o-ring on it...
    <tuffty/>
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    I'll get the kit and hopefully the damage to the dv isn't too bad
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    Cheers Tuffty I looked it up and I'll order it now, was thinking of replacing the dv altogether but the cost has gone up a bit
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    Ok after months of enduring this horrible fluttering noise I had a proper look and found this
    I think a mechanic has bodged the pcv valve breather pipe with tape causing it to rip and cause a vac leak I ordered a new breather pipe and the car sounds much better plus it pulls better to! Case closed!
    Feb 2013
    58
    i have the exact same noise, serviced the forge 007p dv yesterday and its still there, can only assume i have leak some where, i have the bits to remove sai, and simplify the pcv but not mechanically minded enough to fit, cant find any where local that smoke tests,
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    fitted this and the car sounds much better
    Forge Motorsport | Alloy Fabrication
    azman likes this.
  1. Gearbox? Driveshaft ? noise can someone help please ?
    By dentsy in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 20th February 2011, 10:57
  2. CAN SOMEONE HELP ME!
    By S3 SAF in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2007, 10:23
  3. can someone help me out with a part number please
    By imported_kris_tdi in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th February 2006, 20:22
  4. Can someone help me please
    By imported_ANNANBHOY in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th September 2005, 14:16
  5. can someone help me start my audi?
    By treetop3 in forum General Technical / How To
    Last Post: 16th June 2004, 10:47
