Volks AutosEM Tuning
    Jul 2011
    11
    Audi S3 Front Suspension Spring Change Questions
    Hi,
    I'm planning to fit new front suspension springs to an 8L S3.
    How difficult is this job? Are there any special tools or procedures required?
    Thank you,
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Like anything it's easy with the correct tools and experience.
    There are a few gotchas I found.
    1) the top mounts
    2) hub spreader
    3) compressing the springs
    1 you will need a cranked neck ring spanner OR socket which you can hold and put a 7mm Allen key through. Have a look at the top mount (open the bonnet it's the top nut on the strut) and see if you have tools to do this.
    2 to remove the strut from the hub you need to remove the hub *strut clamp* bolt (easy) and then spread the hub to release the strut. There are special tools you can buy to spread this (costs less than a tenner) but I found they don't work too well and the end of a 1/4 inch socket knocked in and twisted 45degrees work far better. IMHO.
    3 I was being a pussy and didn't compress the springs enough when I did this this the first time, I gave up and tried again another day and found it far easier to remove the struts after manning up and compressing the springs.
    You will need a general set of jack, axles stands, spanners, sockets and a torque wrench plus spring compressors.
    Also a 3/8" < 1/4" socket adapter (Laser 0950 Convertor Set includes one) to use in lieu of a hub spreader (Laser 3396 Strut Nut Tool), spanner/socket for the top nut and a long 7mm allen socket for the top nut.
    If you're doing this change your top mounts and bearings at the same time to save doing this in the near future. Oem parts are only £30 and you have to remove and refit them as part of this process anyway.
    Torque everything up correctly (using new bolts where appropriate) else you'll risk winning a Darwin Award.
    Use google, all this is pretty well documented in this forum and others and posting a question because you didn't do a little research or read the stickies/faqs will mean you won't get very many answers.
    Where are you located?
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Jul 2011
    11
    Thanks for your help. I'm located in Edinburgh. I done some research and found etka online.. Which is handy VIN-online.ru (ETKA) - Audi A3/S3/Sportback/qu., 2002 - Подвеска Амортизатор Стабилизатор
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Ah too far away to help. Good luck.
    Liam
    Jul 2011
    11
    Here's one fitted. Wasn't too bad.
  1. Audi A4 B7 Suspension Springs
    By Chets in forum For Sale/Wanted - Audi Parts
    Last Post: 8th May 2012, 20:42
  2. Front suspension springs 2002 S3 Wanted
    By handy andy in forum For Sale/Wanted - Audi Parts
    Last Post: 6th June 2011, 23:22
  3. Bang!!!Broken front suspension spring.
    By handy andy in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th June 2011, 19:40
  4. Front suspension spring: wanted
    By dan-quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2010, 20:33
  5. Front suspension springs
    By chip-3door in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd August 2007, 14:01
