Chris NottMonster Motorsport
Results 1 to 12 of 12
    Mar 2013
    aylesbury
    6
    audi a3 misfire and its not the coilpack or icm
    Hi all i have a audi a3 1998 1.8t engine code agu
    Right the car just started to missfire so i pulled the plugs on the coilpacks and no3 did not do anything so i went and brought a new coilpack fitted that, only to find the misfire is still there.so i went and purchased a new ignition control module from allparts fitted this to find the misfire is still there but now is on cylinder4 i have checked power coming out of the module on all 4 with the car running and they are all at 14volts and the same upto the coilpacks,also checked the earth which all seems fine,If i put the test light on the positive terminal on the battery and put on the wire from the module to coilpack on 1,2,3 the car goes to die but on number 4 does nothing could it be a faulty ignition module or possibly a ecu fault anyhelp would be really helpful as i have tried everything i can think of even start to check all the wires in the loom and still nothing
    Oct 2007
    111
    check compression on the effected cylinder. i had this problem on my old agu and it was the old ignition amplifier but i just used to pull the plug and clean it out from time to time. Also check the pins on the amplifier plug, maybe squirt some cleaner in there.
    Vwdan80's Avatar
    Nov 2011
    South east
    100
    It does sound like a faulty part, try putting the original part back on and see if the misfire moves back to cylinder 3.
    2002 s3 silver, BAM, lcr Brembos ds2500 pads, Braided hoses, forge 008 dv, stack boost gauge, power flex dog bone bush/wishbone bushes, forge boost hoses, B5 tip, B5 remap, toyo fmic
    Mar 2013
    aylesbury
    6
    hi thanks for the reply the compression was 174 180 180 182 forgot to say i had checked that i am just lost as the icm is new
    Vwdan80's Avatar
    Nov 2011
    South east
    100
    If its not a genuine part then it could be playing up, try the original again as it would confirm if the wiring is ok on cylinder 4
    Mar 2013
    aylesbury
    6
    i took the old icm apart to find that two of the soldered bits were broke and if i put it on the car struggles to even start
    Vwdan80's Avatar
    Nov 2011
    South east
    100
    If the part isn't genuine then it could still be faulty, I would put the original back on to at least confirm the wiring is ok on cylinder 4
    Vwdan80's Avatar
    Nov 2011
    South east
    100
    Forget last post, stupid internet playing up
    I would take the part back to the shop saying its faulty and get another to try
    Mar 2013
    aylesbury
    6
    Right put another new ignition control module on and still exactly the same but after some more testing it is pointing to the ecu as the 4 wires from ecu to the ignition module 3 of them have .22v going through and the other only had .06 and it was this measurement coming out the ecu so to me points to the ecu anyone have any ideas thanks
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Have you looked at the coilpack wiring harness/loom? They do a good job of falling apart around the hot parts of the engine.
    Whip the connector off the ECU, trace the wires and check their resistances?
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Mar 2013
    aylesbury
    6
    Yes it all seems fine all getting the same from the icm to the coilpacks opened up the ecu but can't see any bits burnt out !!!
    Mar 2013
    aylesbury
    6
    Just thought I would update everyone that when I rechecked the wiring 1 wire from the ecu to the icm had less voltage it turned out to be an ecu fault so since my obd port is not working I brought a unlocked mapped ecu for 200quid and now runs sweet and also a lot more enjoyable to drive !!!!!
  1. Misfire and oil in the coolant? Need some help
    By mitchs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th December 2011, 23:09
  2. Stumped! Hope its not the timing chain!
    By Karl-g in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2011, 19:05
  3. 1.8t timing issue, hoping its not the cam chain!£?
    Last Post: 22nd July 2011, 01:09
  4. Replies: 11
    Last Post: 11th May 2005, 12:58
  5. Replies: 7
    Last Post: 25th February 2005, 17:04
