AH FabricationsEM Tuning
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    S3 eating lambda sensors... any advice?!
    My s3 has so far eaten 2 brand new bosch lambda sensors in 12 months.
    What can be causing this? Also i think it may be down to fueling as the car once upto temp will drop the revs to near stalling when gearing down and the clutch isnt engaged, also the exhaust does smell rich.
    Now avlo's coming over tomorrow for me to log his car and i may do mine so what are the best blocks to log for fuel, timing and boost?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Get it on a dyno dani... need to see what the AFR is doing...
    Sounds like it could be running rich... have you still got the N249/N112 plugged in? is the rear lambda plugged in also?
    <tuffty/>
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    I know mate, should be on one, on the 17th of march, with mine been narrowband i cant log these via vag-com can i?
    N112 is as i remember when welly disconnected it, it messed his fuelling up, the n249 is disconnected though, that should matter should it?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    So any logs i can do tomorrow then on mine? Going to log airflow and boost and see why i can make 16psi in my standard map lol and also if it makes anymore g/s since the last lot of mods.
  1. Replies: 4
    Last Post: 10th October 2012, 18:56
  2. Lambda Sensor/De-cat Advice Needed
    By dany2k in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th December 2010, 21:23
  3. Lambda Sensor
    By Speedo in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2004, 09:23
  4. How annoying! Ive scratched my alloys. Any advice?
    By stevethejambo in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2004, 12:31
  5. Wireless network thingy stuff ... any advice?
    By wigginer in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 16th January 2004, 09:59
