Chris NottAH Fabrications
Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By superkarl
Thread: 1999 1.9TDi Gearbox Differential Issue - Cheap fix?
    Feb 2013
    Fareham, Hampshire
    23
    I'm currently experiencing problems with steering/braking, which my garage tells me is mainly due to the differential bearing in my gearbox on it's way out. The symptoms are very similar to warped brake discs, i.e. wobbling when braking, and also slight wheel wobble at high speed.
    When jacking up the front of the car, and rotating the nearside front wheel by hand, there is a very audible grinding/crunching noise, which seems rather odd.
    So, my question is, is there an affordable solution to replacing this bearing without a specialist charging a fortune for a full gearbox stripdown and rebuild?
    Any advice much appreciated.
    Bob
    Cobra88's Avatar
    Sep 2011
    Live in Ipswich Suffolk (orig from W London)
    431
    Hi Bob
    what model tdi 90, 110. 115 etc
    if it's a 5 speed i have a spare gearbox in useable condition
    nice and cheap as it's in my way
    Regards
    Rick
    2004 Audi A4 (B6) 1.9Tdi 130 Sport (6) Avant in Dolphin Grey.
    18" S4 AVUS, RS4 Rear Roll Bar, Leather Alacantra Sport Seats, Shark Performance 170 Remap,
    BOSE, XtronsA4A double din, Full DIS, Autolocks & Alarm Chirp.
    Avant Sport 1.8T Valance with twin exit.
    Feb 2013
    Fareham, Hampshire
    23
    Hey Rick, Thanks for your reply. It's a 5 speed, 1999 model on a V plate. I believe it's a 110. The engine code is AHF. My garage told me that it's fairly important that the gearbox numbers match? Apparently they are not all compatible. Maybe you can shed some light on this? Sounds like you know your stuff Do you know the mileage on your box?
    Bob
    Cobra88's Avatar
    Sep 2011
    431
    Hi Bob
    The gearbox i have is off a 2002 Skoda Octavia ASV engined car
    Gearbox is coded EGS and seller listed as 66,000 miles.
    I didn't use it as my problem turned out to not be the Gearbox but was a wheel bearing in the end.
    if yours is EGS it will be fine (look om white sticker in your boot (offside in spare wheel well) three letters will be AHF for your engine then the next 3 letter one should be your gearbox code ---- EGS with luck.
    if you can't find white sticker same as is inside your service book near the front
    Regards
    Rick
    Feb 2013
    Fareham, Hampshire
    23
    Looks like mine is an EBF
    Cobra88's Avatar
    Sep 2011
    431
    Hi Bob
    I will need to see what the difference is between the EGS & EBF boxes
    they are both 110 hp so there can't be much
    probably just final drive ratio at a guess
    My EGS has very long ratios which i like with a tuned diesel
    I will have a dig and report back mate
    Regards
    Rick
    Feb 2013
    Fareham, Hampshire
    23
    Thanks Rick, that's really kind of you.
    Bob
    Cobra88's Avatar
    Sep 2011
    431
    Hi Bob
    Just designation thats different
    EGS is interchangable with EBF
    Both ASV & AHF use same block & flywheel clutch & starter motor.
    only the ASV has forged Mahle pistons and oil jets
    the AHF uses cast pistons with no oil jets.
    EGS 'Beetle03'
    1st 34/9 (3.78)
    2nd 33/16 (2.06)
    3rd 31/23 (1.35)
    4th 29/30 (0.967)
    5th 30/39 (0.769)
    3.389 final
    EBF 'Bora01'
    1st 34/9 (3.78)
    2nd 33/16 (2.06)
    3rd 31/23 (1.35)
    4th 29/30 (0.967)
    5th 30/39 (0.769)
    3.389 final
    So you will be fine.
    Where are you based as you have nada in your location
    Regards
    Rick
    Feb 2013
    Fareham, Hampshire
    23
    Hi Mate, i'm in Fareham, near Portsmouth. What price are you looking for?
    Cobra88's Avatar
    Sep 2011
    431
    Hi Bob
    Can you get to Ipswich to collect it ?
    if you can you can have it for free (Bargain as i payed £200)
    mainly as it will be an Ar**ache to post
    That will make it worth travelling to collect as it will cost you about £40 to get here and back in diesel if your car still works.
    Box is worth nothing to me when it's in my way
    Regards
    Rick
    Feb 2013
    Fareham, Hampshire
    23
    Hi Rick, yes that's not a problem. That's extremely kind, I'm sure we can come to some mutual arrangement in some way. I'll talk to my garage to double check its gonna fit. I'm sure you are right though. PM me your details and i'll be in touch later on, I have to shoot out now. Thanks again!
    Bob
    Cobra88's Avatar
    Sep 2011
    431
    Hi Bob
    No worries mate
    found this thread on these forums about tdi bopx compatibility
    http://www.google.co.uk/url?sa=t&rct...f8s_dATCY_Kkxw
    Feb 2012
    Pie eating land
    1,341
    Follow ruffrida On Twitter Visit ruffrida's Youtube Channel
    You are a good lad Rick, never fault ya, always willing to help out someone with another oil burner, really makes me want my 8L back, boo hoo !!
    Hope ya well?
    B6 1.9tdi Quattro Avant Sport:
    My Build Thread = http://www.audi-sport.net/vb/a4-a4-c...so-begins.html
    Coming soon: -35mm Springs, Colour coded FOG grills, Trip stalk upgrade.
    Wish List; FMIC, BV43 turbo, Bigger Remap, Fat Clutch,Full Stainless, S4 Brakes, 5m mspacers - front, 10mm spacers rear, MFSW.
    Cobra88's Avatar
    Sep 2011
    431
    Hi Adam
    Yep i'm fine mate
    How you getting on with that spagetti wagon?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    this is forums at their best
    ruffrida likes this.
    Feb 2013
    Fareham, Hampshire
    23
    Hi Rick,
    I would imaging we can give this a try, so thank you very much for your kind offer. This kind of thing really does restore your faith in human nature, and as SuperKarl says, this really is forums at their best! When is usually a good time for you in terms of collection?
    Thanks again mate!
    Bob
    Cobra88's Avatar
    Sep 2011
    431
    Not a problem
    i have limited space as im a biker too
    laugh my arse off looking in the classifieds with people selling their old exhaust etc
    i dont see the point and im not that tight
    If your up the creek and i have a part you need then you are welcome to it.
    spent many years racing cars and bikes and the club scene is a bit like this.
    if you get stuck someone will help if they can.
    thats how i work.
    Regards
    Rick
    Feb 2012
    Pie eating land
    1,341
    Quote Originally Posted by Cobra88 View Post
    Hi Adam
    Yep i'm fine mate
    How you getting on with that spaghetti wagon?
    Hi Rick,
    hate every min of it, its like driving a tin can!!
    Know what ya mean about the race scene its just the way we do things, a friend in need is a friend in deed! Cant fault ya
  1. Multi-tronic gearbox issue - possible fix
    By samuelt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th April 2011, 13:09
  2. 1999 A4 TDI - any known issues?
    By ManicMunky in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th December 2008, 15:33
  3. S8 Gearbox / ECU issues + 'Safe or Limp Home' mode
    By AWedder999 in forum A8/S8 forum
    Last Post: 24th November 2007, 01:08
  4. New member; A4 1999 1.9TDI 110 SE sport; pics and problems!
    By Mr K in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th July 2007, 14:00
  5. cheap fix for notchy gear changes
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2006, 07:51
