EM TuningChris Nott
Results 1 to 1 of 1
    Dec 2011
    Bedfordshire
    127
    Cam shaft position sensor fault????
    Hi recently my car has been making a loud clicking noise under acceleration since I did a 30 min track day at silverstone now seems down on power so I scanned it and got the code 17746 camshaft position sensor g40 open or short to plus. Ticks over fine when I googled it a lot of the results were saying I the cam could have jumped a tooth? If so what do I need to do new timing belt or have it adjusted? Also will it do any more damage if I still drive it. Also I have just checked the cam belt briefly and does not seem lose as if a tensioner has gone or anything
  1. A4 1.8T -Idle speed fluctuating and Camshaft Position Sensor fault!
    By AudiStew in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th September 2010, 19:30
  2. Cam shaft sensor = EML
    By chrissy1502002 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st March 2010, 10:51
  3. Cam Shaft Sensor/ Starting Problems
    By ben_turbo1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th January 2010, 19:33
  4. AF FSI 2.0 Cam Sensor fault
    By RLilleyman in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th September 2009, 18:42
  5. A4 2.0 FSI Cam Sensor Fault
    By RLilleyman in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th September 2009, 17:51
