Results 1 to 12 of 12
    epox's Avatar
    Oct 2012
    Glasgow
    567
    is it Possible to check for mileage with vcds
    hi team
    as above.
    and how to if poss on a 2003 s3.
    thanks mark
    Feb 2008
    24
    It probably is but Im unsure how to do it.
    A good way of checking if mileage is genuine is to fire the Reg and V5 document reference number into the DVLA mot site. It will then bring up every MOT the car has had and you can follow the mileages up. Obv if it suddenly drops its been clocked...
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,431
    As far as i remember, the mileage is stored in your ecu, but im not sure if that is visible with vcds. Possibly ask down in the vcds section. x
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Yes.
    Via the Engine 01.
    Its in kph.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    epox's Avatar
    Oct 2012
    Glasgow
    567
    thanks
    phil miller's Avatar
    Sep 2012
    Devon
    843
    carry out a full scan and it will be there for all to see, although, that is the mileage the ecu has done, it may of had a different ecu..... or even a mileage correction with Vag Tacho, ive fitted a few clusters and corrected the mileage (always to the old clusters readings) some people dont do it the same as me though
    ​Wish Rachel would let me have my TDI mk5 back
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    so your ECU stores a different mileage to your clock display ?
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Apr 2012
    605
    Re: is it Possible to check for mileage with vcds
    Go on.to mot.gov then u have mileage every mot as well
    epox's Avatar
    Oct 2012
    Glasgow
    567
    just want to check, no real reason.
    mot.gov will only show mot mileage. could be clocked inbetween.
    cheers mark
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    I've just got my car back from having a clutch fitted and now my mileage counter isn't gaining any miles, is there some in vagcom/ vcds that needs to be looked at or back to garage and get them to see if something isn't connected properly?
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
    May 2012
    RETFORD, NOTTS
    1,753
    Sounds like a plug not plugged back in, but does the speedo work?
    Ive just looked on my 8l tdi and milage is in the ch 17 under measuring blocks but i cant remember which one, it is obvious when you see it though, mine was in miles.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Jun 2012
    Redhill Surrey
    635
    Yeah speedo and rev counter work the mileage is just staying put
  1. Checking genuine mileage using VCDS ??
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th January 2014, 13:44
  2. Possible to check for"mileage correction" via vag com?
    By tedward in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th August 2012, 23:22
  3. Checking mileage with VagCom?
    By jojo in forum General Automotive Chat
    Last Post: 24th October 2011, 10:36
  4. Audi A4 Symphony headunit for sale with radio code
    By imported_Tariq in forum In-Car Entertainment
    Last Post: 25th October 2004, 23:40
  5. Anyone fancy a custom Milltek for A3 with S3 Bumpe
    By nfluester in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2004, 10:31
