- Joined
- Nov 11, 2009
- Messages
- 10,099
- Reaction score
- 739
- Points
- 38
- Location
- west yorks
- Website
- www.stainless-engineering.co.uk
Guys, why don't u use original window washer tank to do both things, wash windows and WMI And it has level sensor as well.
Dont have to fit special tank for WMI, just fill your window washer tank more often and thats it, even OEM look stays.
Won't the meth destroy the window rubbers etc.
And don't think screen wash would be great in the engine lol
Screen wash liquid is same as just any other mixed methanol and water U can even choose how strong mix u wanna use, they even sell those 50% meth washer liquids in almost every gas station.
Well been out and re soldered all of the wiring.
Also added a switch so I can isolate it if needed.
Now all I need to do is figure a way of testing accurately when it is activating. I have the controller set to where I believe it needs to be. But would like to test it does activate when I want it to
Any suggestions
Also what water do you guys mix with the meth? Is it diionised or distilled. Of just tap?
Sorry but £9 for 4 litres is a rip off, i get 25 litres for £12 and i dont know them from adam!!I use the AEM kit on my car,running between 25-50% methanol.
Methanol I get from my local model aircraft and car shop,at around £9 for 4L,which is pretty reasonable.
I always use demineralised water.
Demineralized is deionized, much the same as distilled.
How do you safely store it?
I either keep it in the house or garage.Got some de-ionised water from asda this morning. 75p for 2.5L on sale so grabbed a few.
Do you use any special container to store it in or just the 25L container it comes in?
Will store it in my shed as that sounds the most sensible lol
Got Meth!
Got some meth dropped off last night so tank is now filled ready to test.
First real test will be on way home late tonight, but hopefully get a feel for it on way.
Have you fitted a solenoid to avoid syphoning? If not you want to keep an eye on it as im on my 3rd AEM nozzle as they are leaky cack!
do you use a check valve Westy?
I have two check valves on. No solenoid. (Yet possibly)
I have an inline check valve and the one built into the nozzle.
Do you think a solenoid is still necessary?
Westy- how much was yours and where did you get it from.
Finish at 23:30 tho so should get to open up a bit on the journey home.
