    Jun 2012
    Aberfeldy,Scotland or Antrim, NI
    147
    Exclamation Urgent advice needed!!
    Right ladies and gents, need help asap. Basically bought some FK AK coilovers (FK AK STREET COILOVER SUSPENSION KIT A3 S3 8L TT 8N QUATTRO GOLF 4 4MOTION R32 | eBay) these exact ones. Now, ive fitted one side on the rear and with the adjustable cups about an inch off their lowest, the coils on the springs appear to be touching. Now bearing in mind that the springs have a clear rubber pipe over them, is this ok or am i gonna have to put the standard ones back on?
    Ive searched the few excellent threads and how tos on here but nothing like this is mentioned.
    Also while im here, the adjustable seat doesnt seem to be sat on the rubber seat on the rear arm fully. Remove it? Or will it settle?
    Thanks in advance everyone, much appreciate any help.
    Kris.
    2002 Nogaro Blue 8L Facelift S3
    WTB. Concert CD player unscratched (8L0035186G)
    Heater control unit unscratched (8L0820043H)
    Headlight switch. (
    Vwdan80's Avatar
    Nov 2011
    South east
    100
    I would be good if you could post a picture up to give people an idea of how the spring looks, also I would remove the bottom rubber cushion to allow the adjuster to sit flat. Hope this helps
    2002 s3 silver, BAM, lcr Brembos ds2500 pads, Braided hoses, forge 008 dv, stack boost gauge, power flex dog bone bush/wishbone bushes, forge boost hoses, B5 tip, B5 remap, toyo fmic
    Jun 2012
    147
    After spending the past half hour using my frankly crap google fu and on the phone to a mechanic mate, i have discovered that apparently it is pretty normal as theyre progressive springs rather than linear. Mate said that they will settle in after a few miles. Ill get a pic of the rubber seat in a bit so you can see what i mean. Thanks for the help mate.
    Headlight switch. (
    Jun 2012
    147
    Took her for a wee drive earlier and theyve settled in. Handling absolutely transformed!! A lot stiffer but really good through the twisties!
    Headlight switch. (
  1. Urgent advice needed - A6 2.5 TDI
    By BobA6 in forum Diesel forum
    Last Post: 22nd June 2008, 12:35
  2. A4 1.8T CVT problem, urgent advice needed!
    By a4_jim in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th June 2008, 12:40
  3. Another Newbie...with some urgent advice needed!!
    By Si_Sline_Cab in forum The Welcome Section
    Last Post: 8th June 2007, 00:30
  4. urgent advice needed
    By shufti in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2007, 17:35
  5. Urgent Advice Needed Please with my Audi S3
    By lUCKYS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th August 2006, 12:53
