Chris NottMonster Motorsport
Results 1 to 10 of 10
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    Speed sensor fault code
    P0501 code speed sensor gone on mine,where is this based?,(going into the gearbox),not to sure in where it goes (is).my speedo has stoped working,and also fuel gauge,not fun.and help appreciated
    Audi S3- 1.8T Quattro
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Is that an anagram....
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    sorry s3 dave spelling corrected
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Not sure if they are off the speed pulse on these, never seen a connector going into the box..
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    no that's where i am lost.can't seem to find any info on where they go or connect : (
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    it say's that link has expired.can't see it.so that does conclude it is on the back of the box?,thanks dave....
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Try the link again... it works for me...
    Not an S3 box but maybe similar....
    020 | Flickr - Photo Sharing!
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    yep must be located there then,or similar place.thank's for your help,could'nt see where they fit onto.
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,559
    Speedo sensor is towards the bulkhead side of the box.... (back of the engine bay...)
    Your fault code equates to a 16885 code...
    16885/P0501/001281 - Ross-Tech Wiki
    Implausible signal fault is typically when the sensor values are out of bounds of what the ECU is expecting... normally indicative of a wiring fault or dying sensor...
    <tuffty/>
  1. ABS G45 Front Speed Sensor - Fault
    By Watty in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th August 2010, 23:53
  2. MAP sensor fault code 16492
    By RLilleyman in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th September 2009, 20:07
  3. ABS Throwing fault Wheel Speed Sensor
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th January 2009, 15:15
  4. DSG Fault A3 8P - Clutch temperature monitoring & Transmission Input Speed Sensor
    By mattandrew in forum VCDS (formerly VAG-COM) forum
    Last Post: 19th June 2008, 18:54
  5. Engine Speed Sensor Fault code 16706
    By Felon in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2008, 08:07
