Chris NottSky Insurance
Results 1 to 8 of 8
    Feb 2012
    23
    Rear washer connector
    I've been tracking down the cause of my rear washer not working and found a split corrugated plastic pipe under the scuttle panel (in with the wiring loom - genius idea Audi!).
    I was trying to find the part number for the male/female push connectors used elsewhere in the washer system but my local Audi guy kept trying to say I needed a different part (113955975c) which is a check valve.
    Does anybody know the part numbers of the bits I need as my search hasn't come up with anything.
    I also need the part number for the washer push connector that goes directly onto the rear washer motor as it is cracked too.
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    353
    the connector onto my rear washer motor split aswell and i couldnt find a part number so i just replaced the section of hose with a 3m section of 4mm silicone hose i had lying around
    Feb 2012
    23
    I see.
    Did you replace the bit from the rear washer up to the connector in the boot or the whole lot front to back?
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    If you havnt already sign up on www.vagcat.com go to the parts catalogue, select auid a3/s3, selector your year, select electrical systems, scroll down and select wash and wipe system for rear window, this will give you the parts diagram and parts no. for the rear wash system - Audi A3/S3/quattro 2000
    This repair kit might be what you need for your other problem - Rear washer jet repair kit 8L0998711 VAG Products German Auto Spares - suppliers of VAG Febi Car Spare Parts
    Feb 2012
    23
    Thanks for that Mk1 Chopper. I'll get registered on there and see which parts come up.
    The part I need isn't in that repair kit.
    Feb 2012
    23
    I've ended up just buying a 3mm male-male hose connector to fix the front piece.
    It's not very clear on the vagcat site which item is needed so I will have to pop in past Audi and get them to check.
    mattyboy199's Avatar
    Nov 2005
    UK
    1,676
    I used a 4mm connector
    4mm nylon barbed | eBay
    see thread
    Cheap reliable rear wash fix
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Feb 2012
    23
    Thanks for that. I was going to try something similar on the rear. I has a 4mm 90degree connector lying about which i tried to use on the front, but couldn't get it in the corrugated plastic tubing, so thought I'd try the 3mm ones.
  1. Rear washer line, connector section in rear left arch
    By Squirrelofdoom in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th September 2012, 20:51
  2. Rear washer pipe split or popped connector near head lining
    By leach76 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th February 2012, 12:48
  3. Rear Washer
    By bkmullin in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th March 2004, 14:41
  4. Rear Washer Problem 2
    By Woodster in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2004, 20:06
  5. S3 rear washer jet problem
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2004, 15:34
