JMB RetrofitsVolks Autos
    Feb 2012
    11
    aftermarket parking sensors
    hi guys I have purchased an aftermarket rear parking sensor kit and need some advice about the wiring. There is a red (power) and black (earth) wire with the kit. Which colour lead on the rear light box powers the reverse lights and earth.
    Also how can i route the wires from behind the bumpers to the boot
    cheers
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    Earth just needs to be earthed to the chassie doesnt need to come back to light loom, as for the reverse light power i'd sugest getting yourself a multimeter or trace the circuit on the light cluster back to the loom plug and identify the corrisponding pin, the same method can be used to identify the earth/negative cable on the loom. Unsure of routing of cables but im sure with the bumper off, the boot carpet out and the car jacked up you'll find an existing hole or gromet to feed the cabling through.
    Feb 2012
    11
    Quote Originally Posted by mk1chopper View Post
    thanks that helps a lot.
  1. Aftermarket Parking Sensors to OEM Parking Sensors?
    By a6-chris in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd May 2012, 20:09
  2. Aftermarket Parking Sensor reverse light feed question
    By Ninja21 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th February 2012, 14:02
  3. Aftermarket parking sensors? Anyone done them?
    By S3 MRU in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st January 2011, 23:56
  4. Aftermarket Rear Parking Sensors
    By hfu in forum Detailing
    Last Post: 15th April 2004, 14:15
  5. Aftermarket Rear Parking Sensors
    By hfu in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2004, 13:02
