EM TuningChris Nott
Results 1 to 11 of 11
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    668
    Busy weekend....Hopefully!
    Whoooo, so the list goes as follows:
    Fit 80mm Tip,
    Poly bush anti roll bar bushes (Front)
    Replace outer CV boots on both sides,
    Oil and filter change,
    New battery (my 1 is f*cked, every time I get in it, it struggles to start and is becoming a PITA)
    Remove Fog lights as 1 is broken, and for better SMIC air flow.
    If I change my battery am I likely to get any issues when the new one is connected? Throttle body alignment etc? or will it be ok?
    Hopefully I can get the car on my old mans ramps, but if not it shall be all done on the drive, on or off axle stands!
    Next month will be the following:
    Front and rear bushes for the wishbones,
    rear trailing arm bushes,
    Coilovers (hopefully)
    Refurbed wheels.
    Cambelt change is very soon too. God, anything else
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,398
    Certainly looks like your going to be very busy. Hope the weather is kind to you. Look forward to reading all about your progress, dont forget the pics. x
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    668
    Thanks Sandra,
    I will try to remember to take pictures, but I will probably leave my phone in the house as I hate phone calls and txts when im under the car haha.
    Its been a long time coming, last weekend I changed the topmounts only to find a broke spring
    hopefully the weekend is all straight forward!
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,398
    Quote Originally Posted by s3clarke View Post
    Thanks Sandra,
    As long as you do a write up on your progress, i may be kind and let you off with the pics. Btw, put your phone in flight mode, works great. x i look forward to reading this very soon. x
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    668
    Quote Originally Posted by Sandra View Post
    good idea to the flight mode ok I will take some pictures that's if it all turns up in time for the weekend, order it all yesterday..
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    668
    Well my busy weekend is not so busy now as my TIP hasn't been delivered.. Anti roll bar bushes along with cv boots tomorrow then..
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,398
    thats not good to hear, well you just need to do other stuff instead. x
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    668
    Wheyy it has turned up now :D
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,398
    well go get started, rem phone in flight mode, take pics as you go along and i will see the progress later. Have fun. x
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    668
    Well my 'busy weekend' turned into a nightmare as after thinking I had a squeal from a split pipe on my TIP, I then discovered its actually coming from the turbo. 1 bent fin, and slight side to side movement causing the blades to catch the housing.
    I fitted the tip and the anti'roll bar bushes so I could get the car home, but this weekend will be turbo off job to inspect what needs replacing.
    Mar 2011
    Milton keynes
    150
    Sorry to hear about your possible turbo change there! I had to do mine a while back and it's not too quick a job, I think added up it took about 8 hours or so over two days. The turbo is a right pain to get to but I managed it so anything's possible. There should be a guide on here somewhere have a look through and see :-) . Good work with doing the other bits you had to do though, I always find I start one job and encounter something else to add to the list lol. Good luck with the turbo work bud :-) Jon
  1. Busy weekend cleaning ready for GTI Inters
    By Speedy Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2011, 20:30
  2. Busy weekend in preparation for gti inters!!!!
    By AARON77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2011, 10:39
  3. A busy weekend of working on the motor....
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2010, 12:29
  4. AmD and Milltek Have a Busy Weekend!
    By shaun@amdessex.com in forum R8 Forum
    Last Post: 10th October 2008, 09:56
  5. AmD and Milltek Have a Busy Weekend!
    By shaun@amdessex.com in forum TT/TT-S/TT-RS Forum
    Last Post: 9th October 2008, 11:01
